Hey guys, buying some fans and wanted some advice.
Here is my spec:
BitFenix Shinobi case
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155
Gigabyte GA-Z68XP-UD4 Z68 Socket 1155
Gigabyte GeForce GTX 560Ti OC 1024MB
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Samsung F4EG 2TB HDD
Titan Fenrir Evo
Corsair CMPSU-850HX Professional Series 850W Power Supply
Here's the fan options for the case:
- Front Cooling: 2 x 120mm Fans (optional)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
I don't think I need anything too extreme. Thought of getting some Gentle Typhoons and getting a fan controller but doesn't seem worthwhile considering my parts at the moment.
Considering two Antec tri-cool 120mm fans. Not sure if I should just get 4 of them or two 140mm fans to go with it.
Cheers for any help.
Here is my spec:
Titan Fenrir Evo
