It's just annoying that so many people call him 'Hawkins'
You wouldn't see anything. You are travelling faster than light has the ability to enter your pupils to register an image.
If you go in a straight line. Because you've gone round something you'll arrive at your starting point before you left*Surely you'd go forward in time?
There's a really good Stephen Hawkins video about it.
The speed of light is a constant bound by the universe, Photons only adhere to this maximum.
I prefer to think of it using an analogy that is close to the truth, space and time are finite and measurable, if we are to live in a 4 dimensional space-time where all 4 dimensions are facets of the same thing, then there must be a number, a figure or a concept to convert units from one dimension to another, where we deal with the 3 of space its a 1:1 conversion, 1 cm is 1 cm in any direction, although how does this relate to time, which is conceptually distinct, the answer lies in that number c .
Its a mental idea but maybe holds a smidgen of fact somewhere, we just dont know tbh...
But no, if you could travel faster than the speed of light you would not run into yourself, because you are not travelling back in time any faster than you were when you started speeding away at c+some speed. So you would just be a self contained anomoly![]()
considering your mass would be infinite
If you went round faster than the speed of light you'd arrive before you left, so you would go back in time. You would see yourself leave. Maybe![]()
Travelling at near the speed of light would take you into the future, as strange as it sounds, Hawking's Into The Universe episode 2 speaks about this.
Superman didn't when he made the Earth spin backwards and he went much faster than the speed of light; he was doing more than 7 orbits per second in the movie.
what would happen if i broke an unbreakable pencil?
iirc he did it in a figure 8 pattern
There's a whole lot of wrong in this thread...
ok... you cannot have these 3 things (with all three one must fail):
1) Causality - some event causes another event after the original event. The second event CAN NEVER influence the first.
2) Faster than light travel - this is technically the movement of "Information" at FTL speeds. This includes your body.
3) Special Relativity - this is measureable and experimentally confirmed. So giving this up isn't really a great option.
Basically, because of somthing called a Lorentz Transformation, if you could send information Faster than Light, then in some circumstances it is possible to send a message to yourself which would arrive BEFORE you send the actual message.
Your message could be "Do not send this message" - if you recieve it before sending, and do not send the message you are creating a paradox and breaking Causality.
SO, in order for any information to move faster than the speed of light, you need to abandon Cause and Effect - good luck!
Not to mention the fact that accelerating anything with mass to the speed of light requires INFINITE energy.
NO DEAL.
