Fastest desktop hds
4 Oct 2005
Herefordshire
Hi guys i need a little advice on the fastest desktop hds(not raptors)
i primaly use my pc for gaming also watch films on my comp, also i do a lot of ftpin, i download a lot of linux distros for people, and then mail them, charging jsut for p&p, anyhow i want realy fast drives, i will be bying two of them to run in raid 0, i know i would have to pick sata 2 with at least a 16mb cache, jsut wanted ideas on drive makes and models, since i havent bought one in a long time.
many thanks
EDIT: sorry i forgot to add the size i would like, around the 300gb size, ie 320gb ect
Are these any good ?
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM
Hitachi Deskstar T7K500 NCQ 320GB SATA-II 16MB Cache - OEM (0A33435)
i think its going to be a pair of iether the hitache or the seagate
You don't as such need Sata-II IMO, but anyway, it obviously doesn't hurt. My vote goes for the Seagate, but both are good drives. The Seagate has the edge though, due to it's perpendicular recording and 5yr warranty.
thank you i was thinking that too, from what i have read in reviews ect, the seagate is definatley faster, in fact its on par wiht rapters, ie not much in them, bar of course the new one, if only i could afford them i would be bying them, lol anyhow thx for the reply
apart from capacity, of which both drives are the same, what advantage does perpendicular storage have over standard storage. The wikipedia entry for e.g says the only advantage is the the amount of data you can put onto a certain amount of space. If both are 320 then whats the point
The Wikipedia entry is correct, perpendicular recording lets you achieve a higher data density. However by increasing the data density more data passes under the read head per revolution therefore the sustained transfer rate is higher. This is how the 7200.10s keep up with the 74Gb Raptors despite spinning slower.
