- 10 Sep 2010
- Cornwall, England
Hello all.
I've had an issue with my PC for along time now, (6 months + ), whenever I run a 3D application the PC will BSOD, the monitor will loose signal and the PC will restart, then when I get back into windows it gives me an error report. The error report is as follows:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 2057
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA80054174E0
BCP2: FFFFF8801064F23C
BCP3: FFFFFFFFC000009A
BCP4: 0000000000000004
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
This has happened once or twice whilst just browing the internet, but always happens when playing a game or running a benchmark.
The things I've tried:
New Power supply (had a Corsair HX850, now have a NZXT Hale90 1000W)
New motherboard (Tried a gigabyte X58 UD5 and EVGA SLI 3)
New RAM (OCZ 3 x 1GB, now have Corsair Dominator 3 x 2GB 1600)
New HDD( Had 500GB sammy spinpoint, now have 1TB sammy and 80GB SSD)
Tried 4 different nVidia drivers
BIOS update to the latest for both motherboards
2 x different monitors and a TV
3 x monitor cables (a Dual link DVI, normal DVI and a HDMI)
countless fresh installs of Windows 7 home premium 64Bit
Checked all cables are connected properly
This happened with a pair of HD5850's I had before... my system is as follows:
Corsair Dominator 6GB 1600Mhz 8-8-8-24 1T
Corsair Obsidian 800D
Gigabyte GA-EX58-UD5 F13j BIOS
Core i7 920 2.66Ghz D0 @ Stock.
GTX 570 Beast Ed (Factory OC)
Sammy Spinpoint 1TB
OCZ Vertex 2 80GB
LG Blu-Ray player
Lamptron FC6
8 x Fans (12V)
18W DDC 355 Pump
10W DDC 350 Pump
Custom Water for CPU
I've tested both cards in a friends PC, but only for 10 minutes each as he wanted his PC back
I've managed to use my PC for 5 days straight without an issue before and other times my monitor has lost signal even before getting into windows, and once whilst installing windows.
The only thing I haven't replaced is the CPU, however this is running at stock speed and I've even ran Prime95 at stock for 9 hours just to make sure its stable.
Also tried setting the Fan speed to max on the cards but doesn't seem to make any difference in terms of how long it lasts before the PC restarts.
If it happens before entering windows then I'm pretty sure its not a software issue, and I've replaced almost all my components in my PC so I'm really stuck.. Any help is MUCH appreciated, may have to sort out a prize for whoever solves it.
Thanks for reading.
Problem signature:
Locale ID: 2057
BCCode: 116
Service Pack: 0_0
Product: 768_1
Sammy Spinpoint 1TB
OCZ Vertex 2 80GB
LG Blu-Ray player
Lamptron FC6
8 x Fans (12V)
18W DDC 355 Pump
10W DDC 350 Pump
I've managed to use my PC for 5 days straight without an issue before and other times my monitor has lost signal even before getting into windows, and once whilst installing windows.The only thing I haven't replaced is the CPU, however this is running at stock speed and I've even ran Prime95 at stock for 9 hours just to make sure its stable.
Thanks for reading.
