Feel Three Virtual Reality Simulator
Did anything even come of the feel 3 device? i know the yaw guys are just about hanging on, however regardless of the necessities they have kind of screwed over their kickstarter backers and are prioritising new orders over kickstarters. At this point i dont think i would trust my money with them even tho i am sure they are trying their best.
but the feel three project seems to have have no updates made on it in years.... did the backers get their gear (it was meant to be out in 2018 iirc)
As brilliant as these are - that would always be my concern - that is a lot of money to punt on a kickstarter when their conversion rate is pretty poor.
Hi I have it completed and went pretty good , mind you the movements on the rig were as violent as hell until I found the smoothing settings in the software, hardest part of build is drilling and tapping of the 4 large aluminum profiles as these need to be drilled and tapped as square as possible, to ensure smooth movement, otherwise easy with help from discords etc, for trouble shooting,
Fantastic stuff. Have you done a build log? Would you consider putting one together in the Build section - would be great to learn from your journey!
