Hi, upgraded from a A64 4000+ (SD) to a A64 X2 4400+ last week, both Skt 939, see sig for rest of specs. The CPU is the only thing that's changed and nothing is overclocked.
I've had one BSOD while browsing the web (windows encountered a serious error ...etc), one freeze where everything was unresponsive, and a reboot during startup. I also had 2 spontaneous reboots but I think those can be put down to coretemp since it was running at the time and those haven't reoccured since during the last week.
Before changing the CPU the PC was rock solid stable. Temps look fine, highest I've seen is 52 degrees one core and 48 for the other after running two instances of SuperPI 32M for half an hour. Gaming seems fine too, the PC survived a 4 hr game of Supreme Commander. So I don't think it's a temperature issue. Don't think it's power since the PC got through 3 back-to-back runs of 3DMark06 without problems, and the PSU is an Enermax. The hangs seem random rather than relating to system load.
According to Asus the current BIOS on the A8N5X supports my CPU just fine. The only newer BIOS available is a beta (doesn't say what it fixes). So I'm now thinking software issues. I installed the latest AMD CPU driver after installing the X2, then the latest Cool'n'Quiet driver, and then the Dual Core Optimizer. Any reason why I would need to reinstall XP when switching to dual-core? Anything else software-wise that I might have missed?
HSF is Freezer 64 Pro btw /w AS5. Case has dual 12 cm cooling. Only other thing I can think of that's relevant is I have Cool'n'Quiet active (1000 MHz, 1.1 V for each core at idle). Kinda perplexed here...
Cheers for any help,
Simon.
Simon.
I now have plenty more things to try should it start crashing again. I do have the hotfix and dual core optimizer on. Currently running 1T so I'll try 2T, and if I get desperate I'll reinstall XP. There's always that beta bios too.
