FF VII basic help with fighting
Ah, i remembered the catch with Beta, it uses something silly like 75MP which at that point in the game is a huge chunk of your MP. So yeah it will kill nearly anything, but you only get to use it once per rest/ether.
finally, i can use my ether potions :D
that is if i can get the skill finally :p
Ether's are handy in the Battle Arena at the Gold Saucer.
MP=0...I don't think so.:)
I have no idea what that is but i'm looking forward to it.
The only thing i've heard about before, boss wise is Ruby and Emerald... something
Is there a lot of special stuff you can easily miss out on?
Sadly I can't :/ it's a challenge and it's a do-able (albeit difficult one) so i'll keep going till i go mental, or kill him. Whichever comes first
Would that make him a good source of XP?
At the end of the game, yes.
Sadly when it's a struggle to kill him, it's a waste of time doing so. Get Beta, and get out of there. He just respawns and is an absolute **** to kill.
It's not like there's any good loot.
Once you do get Beta from the Zolom it's easy enough to beat but definitely not worth sticking around to build XP.
I think I only got about 240XP from it by the time I got there whereas in the Shinra mansion you get 1200XP for killing a group of 4 easy firey things.
managed to get Beta :D
Instead of making Cloud my main guy with the elemental, fire and ES materia, i set it to Barrett. Then luckily i had him set to Defend after he got hit by beta so he went down to 200hp, then he survived the attack after, drank and elixer and beta'd back :D
Well done you.
It'll come in handy.
Get Big Guard as well and you're damn near indestructible.:)
Well done you.
I had a look at a guide for FFVII and i've not got loads of stuff that i should have got so far. There's a long range materia, some weapons and carbon bangles i was meant to steal.
What does Big Guard do?
gives you a barrier against magic and physical attacks
Honestly I wouldn't bother that much with the guide first time round... Takes the fun out of the game. If you want to 100% the game at a later date then by all means. IMO its more fun to just play the game through and maybe ask firends (us) for tips and advice.
If your anything like me you'll get bored of the game if all your doing is following a list of instructions which in effect take the challenge out of the game.
