Permabanned
- 17 Sep 2014
Do these numbers refer to Mbits, rather than MBytes, right?
Yes, or else it would be 38MBps and 76MBps.
Although usually it's expressed as MB/s or MB/sec to avoid such confusion.
Are you joking? That adds to the confusion!!!!
I wouldn't say so. 38Mbps and 38MBps are easier to confuse than 38Mbps and 38MB/sec. But maybe it's just me!
But thats not what you typed.
Yes it was, in reply to the post I quoted.
Not it wasn't, you wrote
MB/s or MB/sec
now learning the difference bledd, it makes you realise how slow non fibre broadband is!!! I would say 38mps is JUST enough for the most part. ONLY JUST
