Firstly you'll have to remove that link as you can't hint at competitor pricing on this forum (read the rules), i suggest you post it as this:
Intel Core i7-4770K 3.5GHz Quad-Core Processor
Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing CPU Cooler
Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
ASRock B85 Pro4 ATX LGA1150 Motherboard
Corsair 16GB (2 x 8GB) DDR3-1600 Memory
Samsung 840 EVO 120GB 2.5" Solid State Disk
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
MSI GeForce GTX 770 4GB Video Card
Antec One ATX Mid Tower Case
Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Samsung SN-208DB/BEBE DVD/CD Writer
Total: £1081.01
I think you've messed up somewhere along the line in your thinking..
Can i ask some questions:
What is the rig for? Gaming? Editing? CAD?
Are you wanting to upgrade this in a year or so time (add another GPU) or will it just be as is for the next few years? (not a bad thing atall)
I'd really consider buying it all from one (or two if the savings are that good) place. Firstly, any RMA/DSR is easy to deal with and you will pay less shipping. Even though that website said it toook shipping into account, trust me, it hasn't.
What is you're overall budget?
I already removed the link, sorry about that.
- This rig is mainly for Gaming.
- I would not want to upgrade for a while I guess..
- Exactly, my ideal solution would be to buy it all from the same place.
- My overall budget is around £1,000.
+1 for Doomeds basket, only thing i would change is the CPU Cooler and ONLY if you intend to overclock your CPU, if your leaving it at stock then that cpu cooler is perfect.
OEM CPU, no cooler supplied![]()
Yep RJC, hence the CM Hyper cooler, if the budget is £1k, theres a small bit left over to lob onto something like a K2 though![]()
You can't get better than the Superflower PSU.
obviously case limitations etc though, shame no Refurb H100's are available as that would be a decent upgrade
You won't get a h100 in the 200R either.
Research my friend..![]()
Resolution: 1440x900.
A new monitor perhaps.
YOUR BASKET
1 x Sapphire Radeon R9 280X Dual-X OC 3072MB GDDR5 PCI-Express Card with Battlefield 4 PC Game £251.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £249.95
1 x Iiyama Prolite E2481HS-B1 24" Widescreen LED Super Slim Bezel Monitor - Black £149.99
1 x Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £95.99
1 x Plextor M5S 128GB Solid State Drive - (PX-128M5S) £71.99
1 x Toshiba 2TB 7200RPM SATA 6GB/s 32MB Cache - OEM (DT01ACA200) HDD £59.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x Corsair Carbide 200R Compact ATX Case - Black (CC-9011023-WW) £47.99
1 x Cooler Master Hyper 412S CPU Cooler £28.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £1,105.84 (includes shipping : £12.50).
YOUR BASKET
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £86.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
Total : £975.95 (includes shipping : £11.75).
The cooler comes with thermal paste.
Motherboard can take SLI & Crossfire:
YOUR BASKET
1 x MSI Radeon R9 290 "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card £329.99
1 x Seasonic G series 750w '80 Plus Gold' Modular Power Supply £109.99
1 x Gigabyte Z87X-SLI Intel Z87 (Socket 1150) DDR3 ATX Motherboard £97.99
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler £29.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £1,084.96 (includes shipping : £11.75).
Between these two,
They'll perform the same (really) but RJC's has the ability to add another 280x in.. Mine doesn't..
Personally i'll stand by mine but either/or really you're not making a bad purchase atall.
