- 4 Sep 2011
Please could some of you give this a once over? It wouldn't be used for gaming, so no GPU is needed (I'm going to use an old 7300). It will be used predominantly as a virtualisation platform.
I definitely want the i7 due to the hyperthreading support over the i5. Are the motherboard and RAM reasonable choices?
I have a 550w PSU that's 3 years old; would this PSU support this spec, or is it worth purchasing another?
Regards
Regards
