Final speed machine specs.....
Nic Miller said:
Would you recommend a couple of these bad boys in RAID 0 then? Will I notice much difference?
Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache - OEM
Thanks
Nic
That's precisely what I would do, and you will not notice a difference. :)
Also
1TB 4TW!!!!!
Can you use 4Gb in XP? Just wondering as I have the money now and won't be upgrading again for a long time, so makes sense (to me) to put in 4Gb and forget about it.
Also is an E6600 easy to overclock for a beginner - nothing major, just up to E6700 speeds to prevent me from buying that chip!
Thanks
Nic
XP can only utilise 2GB. TBH even under Vista I don't think it's gonna be worth running 4GB till later in the year anyway.
I think you ll find that all the top coolers available (Tower, Noctua, Infinity and Ultra 120) all performs pretty well and it will probably down to personal taste on which one they get.
Also I got my TJ-09 yesterday and it looks lush, you ll love it. Shame my components wont come till monday
Yeah the case looks great - did you get black or silver?
Just need to decide on this damn keyboard! down to either the G15 or the razor tarantula...............pls help !
Personally I think the Tarantula looks tha canines cajones ! Very stylish which is important. Gets good writeups - only down side is the lack of lit keys - but then there is some add on which you can get.
I think the G15 looks a bit naff to be honest! Looks a bit cheap and gimmicky. Would never use the LCD. The macro buttons are on the wrong side of the keyboard as well!
mines the black with window like yours, cost £189 inc delivery
G15 owns(Saitek inc)+ its nice to see how much a game is using my pcs resources while gaming.
a gaming rig isnt a gaming rig without raptors m8 lol tbh if i had the choice again id still have the raptors!..why? they are the fasted sata drives you can get.period
c ya
Damn! I had decided on 2x500Gb seagates.......
Which do I do....1x 150 raptor or 2x500Gb Seagate......seems a no brainer for the same price considering the tiny speed increase!
