I did a critical evaluation into Single Signon within a FOSS network, involved reasearch into current Authentication infrastructures (such as M$ AD and Novell Netware etc) and their backend components and creating a virtualised test enterprise where I configured a linux network to be as 'SSO' friendly as possible using nothing but open source components (And then the whole report writing of the setup/good bits/bad bits/future views etc)
ended up with Kerberos authentication, with kerberos backend data stored in a Multi-master LDAP replicated DB (Plus DNS backended to the same multi-master LDAP arch).
This was then used to authenticate to a second Multi-Maser LDAP DB (for security) in which user profile details for logons and permissions were held.
In the end the User could SSO:
*Onto the WIFI
*Logon to a desktop machine
*Kinit auth themselves onto the network if they were using their own linux laptop
Once on the desktop/Laptop, they:
*Received their user logon profile from the public LDAP along with shares, shell type etc
*Received encrypted authenticated NFS4 Shares for /home/%user%
*Could log onto IMAP via SSO
*Could log into the company intranet via SSO (Firefox configuration does need to occur for this)
*Pull company contact addresses out of the LDAP DB for email client address book
Only issue I had was with 802.1x SSO authentication. I Used OpenRadius and ended up using EAP-TTLS to create a secure tunnel in which to authenticate normally. The problem here is this does NOT create you a kerberos TGT or pass any kerberos info back to your client, so while you are logging on with the same username and password (you only have one un/pw system wide) you still need to KINIT once your laptop is authed onto the wireless network. (Basically two logon steps for this wifi configuration)
However, This should be resolved with the introduction of EAP-KerberosII
http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=4740231.
Hope this helps, may not be your cup of tea at all, but kept me far too busy for far too long
![Stick Out Tongue :P :P](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
... Never writing that much again!
//TrX
EDIT: This stuff seems to be getting better all the time in terms of the integration required for a project of this size, doubt you would run into any MIT kerberos bugs with the very young LDAP backend anymore when using any of the :RC4 ENC types, but may be wrong
