Finished building but can't get it up and running.... HELP
@ The Deuce, like Buchanan0204 I would like to know what I'm supposed to have said that has caused you to make the comment you have?
virtually every post today that you have aimed at me you have altered one way or another, your posts are doing nothing but to try and provoke a response. Quit the patronising and get back on track with the OP's problem.
:confused:
I was the one helping the OP with their problem.
You chipped in to repeat what I'd already said.
wait 3 wires for power?? I have a molex from the top of the case.........there are no other molex's.... there' s a slot above the PCIE but this is labelled SLI / x fire connector - can I use this for powering fans? will the 24 pin + 8 pin be sufficient?
O rly??? I'll have to move that then... and presumably I should move the wire from the spinny fan that came with the H80 to CPU fan instead?
thanks a lot will give it alll a bash tomorrow
still waiting for answers to the above....
Why do you want me not to use the socket labelled CPU fan???? Are you saying I should use the number 2, 4 or 5 on my motherboard to power the CPU cooler, and forget the 3 pin molex attached to it?
I don't own an H80 but I'll try my best.
The cooling block appears to have 2 cables coming from it:
1) A molex connector for power. This needs to be connected to a molex power cable from the power supply.
2) A pump speed monitoring cable which should be connected to the CPU fan connector on the motherboard (4 or 5 on the chart above).
The fans are connected to the 2 connectors on the cooling block.
OK all the fans are spinning now and LEDS on..and the cooler lights up....red power light on the motherboard....
I managed to reach a screen for the motherboard saying detected the processor ... and some ide devices or something
I couldn't press any F keys on the keyboard...... and there was no mouse clearly.....
The keyboard and mouse were both USB.....these are both plugged into the Motherboard USB slots.. I tried switching from usb 2 to 3 and no luck.
I then turned the computer off and tried plugging in the Serial Keyboard ... But now the Picture won't even load up !!!????
what do i do now?
There are no beeps upon power on....just a loud noise.... + fans ... the loud noise cuts out after about 7 seconds or so.....
Ask The Deuce, he seems to have all the answers ;)
Seriously, make sure all the cables are connected securely including the one from the graphics card to the monitor.
You could try connecting the monitor to the outputs on the motherboard just to see if you can get it working.
Try clearing the CMOS. Disconnect the power lead and press the little button on the rear I/O panel.
Edit:
Make sure the RAM is correctly seated in the slots.
Try it with just one stick at a time. Try each of the different RAM slots.
Still nothing......
What the heck.. how can the display come on 1 minute and not the next??
again, fans are spinning, cpu is on.....led is on..
DVD drive is ejecting.....
No lights are on my mouse USB .or keyboard.. USB. or the Serial Keyboard....
Shall I replace the current stick of ram with the other one and see if it boots up ok?
I confirm I am in the bios on the serial keyboard....
Also I was following MOBO instructions as to the seating of the ram.....
Was in slot 1 and 3 from left to right ....
HMM I just turned off the power ....and fired up the computer again without removing the ram stick which booted up....and now I don't have a picture or power to the serial keyboard again??? Nothing has changed - wtf?
done this twice now and it's doing the same thing... wtf?
