Firestrike Extreme Bench.
Isn't Extreme Preset supposed to be running in 2560x1440P ? Then how come I can run it on my other PC in 1920x1080 at Extreme settings and get a positive valid 3dmark result !
Then comparing Extreme results make no sense at all !.
I'm going to plug my old 15" 1024x768 screen to the PC and see if I can run the Extreme test.
Have you tried comparing the scores ??
Yea... they're not the same. I have a friend that bought 3Dmark on steam sale. Has a 1920x1080 screen and a GTX 780 OC, a ci7 3960x oc'ed 4.6GHz and he gets over 5500 in Extreme score. There's no place in the 3dmark score result that shows the resolution used.
This is his extreme score run a 1080 res' http://www.3dmark.com/3dm/1505039
Been having my first attempt at overclocking and have managed to break 5k.
http://www.3dmark.com/3dm/1997553
i5 760 at 4.0Ghz
290X at 1,110 / 1350
Graphics: 5,619
Physics: 6,818
Combined: 2,415
Score: 5,079 :D
Sorted a problem I had with my i5 760 not booting, just needed some extra volts and voila.
If you post a pic of your 290X in the thread below, I can put you on the Roll of Honour in that thread.:)
http://forums.overclockers.co.uk/showthread.php?t=18551717
