Firestrike Extreme Bench.
Windows Vista 64bit SP2 + DX 11
Forceware 332.21
Palit GTX 780 Super Jetstream - 980MHz core, 6.2GHz Memory.
Asus GTX 780 DirectCUII OC - 889MHz core, 6.0GHz Memory
Intel Core i7 3820 [email protected] air cooled
Score 7106 with NVIDIA GeForce GTX 780(2x) and Intel Core i7-3820 Processor
Graphics Score 7973
Physics Score 9516
Combined Score 3237
http://www.3dmark.com/fs/1504620
My poor 3970X lasted just long enough @4.5 to run this
http://www.3dmark.com/3dm/2160150
Four 290Xs on air @1180/1600 - loads more in the tank
Score 16616
AMD Radeon R9 290X(4x) @1180/1600 Air
Intel Core i7-3970X Extreme Edition Processor @4.5 Water
Graphics Score 22777
Physics Score 16156
Combined Score 5565
Now if I can just stop the CPU konking out after a minute or two I may be able to post a good score lol.:D:eek::D
Check the graphics score.:)
Can you not fit the cpu back into a RIVE and clock it there?
Also, I'm waiting for a BE mbd and have been assured the newer Ivy-E cpus are getting better physics at 4.8 ish than my 3960X at 5.47 in them........with good clocking mem of course.
I don't think the mobo is the problem, I think the problem is the CPU. I will find out when I try my 4930k in the BE.
Two in CF with a gap is not a problem but four tend to throttle a bit.:D
If I run them on the Heaven bench, for the first half they are a few frames faster than the Titans but by the end of the second half they are about 20fps behind lol.
That I would like to see. Any closer to getting the water blocks fitted?
