That I would like to see. Any closer to getting the water blocks fitted?
I am giving it a few days then I will fit them.
3x 290X MSI Gamer at 1220/6500
You just beat the legendary scottys water cooled titans on graphics score. Not bad Gibbo. If you don't include a URL you won't get on the leaderboard though.
Don't car about the leader board to be honest, if I did they'd be in an X79 rig running around 5.2GHz with some 3000MHz+ RAM and they'd be clocked higher.![]()
You should still submit a url, its a good score.![]()
My hardcore benching days are over, 8 Pack can go for the records, I had my fame some years back.![]()
Score:6086
Graphics Score 6236
Physics Score 17498
Combined Score 2820
780Ti Ref SC (water) 1305Mhz / 3930Mhz
4960X @ 4.7Ghz
Win 8.1
332.21
http://www.3dmark.com/3dm/2215072
Still not quite up there with the ******* Classifieds![]()
By the power of GREYSKULL/Hexcore
http://www.3dmark.com/3dm/2215722
780Ti SC Ref TRI SLI (water) (STOCK BIOS)
Synced clocks: Boost 1255Mhz / 3900Mhz
4960X @ 4.7
Score: 14544
Graphics Score 17215
Physics Score 17525
Combined Score 6014
Bouncing off the power limit
Cheers Kaap
Bit of light overclocking with i7 4770K and 290X
http://www.3dmark.com/fs/1562648
Graphics: 5,708
Physics: 10,675
Combined: 2,477
Score: 5,381
i7 4770K at 4.2Ghz
Gigabyte Windforce 290X at 1,110/1,450 - stock volts
Scoreboard updated.
Could you confirm what cooling you are using for your GPU and CPU please.![]()
