Just got back from a bike ride!
Rode down to the beach and had a shandy while watching the sunset!
1) My ass hurts (got padded shorts)
Part of this is just getting used to it, part of this is decent shorts, part of this is a decent saddle. Finding the right saddle can be very tricky.
Andr3w said:
2) Occationally I hear the disk 'scrape' even though i'm not holding the brake - what could this be?
Pass, I'm no good on disc brakes.
Andr3w said:
3) In certain gears the chain can be heard rubbing rubbing on the large cog changer. It's really hard to explain as I don't know the terms. Look at this example picture, when the gears on the left are on the hardest (highest?) setting, the gears on the right 'rub' against the changer.
If you're in the small ring at the front and the small gears at the back then it likely will rub. You typically use big front/small back or small front/big back and then there's some crossover in the middle, but at the extremes some rubbing is normal.
Andr3w said:
4) On the little cog, to change to harder gears its the small lever and to change down its the big lever on the right hand gears.
On the big cog, to change to harder gears its the big lever and to change down its the little lever on the left hand gears. Again is this normal or should they both be the same?
It's normal. The big lever tightens the cable, the little lever releases it. The tighter the cable at the front, the bigger - harder - gear you're in. The tighter the cable at the rear, the bigger - easier - gear you're in. It's doubly confusing because a big ring at the front is hard work, but a big ring at the back is easier. Does that make sense?
Andr3w said:
5) To change the gears on the right stick (little cogs) its really easy, just click click click. To change gears on the left hand side (the 2 big cogs) i REALLY have to push quite hard, and even 'hold it' for a few seconds while the change latches on - is this normal?
Yes and no. The rear derailleur only has to move a tiny distance between each of the cogs and it's indexed in such a way that it pings very neatly from one gear to the next. The front derailleur has to move a greater distance, and it's almost certainly just a friction shift (assuming you have a double, rather than a triple?) so it's basically just a case of needing to shift the derailleur until it's in the right spot rather than it having a place to click into like the rear derailleur. It could be that it needs adjusting a bit, depending on which way it's tricky, and it could be to do with the limits or the cable tension, but in general terms yes - the front derailleur is not as precise an affair as the rear one. I assume, however, that shifting down to the small ring at the front is easy, but that shifting up is hard? Shifting down is just about releasing the cable and it should twang free with quite a noise and move fairly quickly. Shifting up is the harder end of things, because the cable has to be pulled quite a way to move the derailleur out and the chain up to the big ring.
Andr3w said:
Does this bike just need bedding in? Should I mess around with it? Should I try find a bike shop to give it a service even though its only 1 day old?
It depends on how confident you are, and how handy you are with the spanners generally. The Park Tool website has excellent explanations of these things, and it doesn't take too much in the way of tools, so it is doable. However, if you're new to it and not confident, then it mightn't hurt to take it into a shop and ask them to just check it over. If you tell them it's from Halfords and offer to buy a few bits and bobs from them then they might just roll their eyes and mutter about Halfords and then give you the 5 minutes it'll take for them to fix it for free. Or maybe find a mate who knows what they're doing bikewise?
Andr3w said:
edit: Enjoy my potato style explanation
Hey, we all started somewhere. The big cogs at the front are usually referred to as the chainrings or rings. The small cogs at the back are usually called sprockets or cogs. Gears is used to refer to all sorts of things, though really it means any particular combination of sprockets. The thing that moves the chain is called a derailleur or mech. It's usual to refer to the mechs as front - being the one at the pedals - and rear - being the one at the wheel.
