- 21 Dec 2010
- Glasgow, Scotland
Hi everyone, im looking for some advice on my first ever build and this seems like a very helpful community to ask
Im trying to build a mid-high range gaming PC and I am wondering if these parts will all work together.
Intel Core i5 760 2.80GHz
http://www.overclockers.co.uk/showproduct.php?prodid=CP-339-IN
Motherboard - Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-399-AS&groupid=701&catid=5&subcat=
RAM - 2 x OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel(So a total of 8GB)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-183-OC
Hard Drive - Western Digital Caviar Green 2TB SATA-II 64MB Cache
http://www.overclockers.co.uk/showproduct.php?prodid=HD-327-WD
Optical Drive - Samsung SH-B123L/BSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATAII Optical Drive
http://www.overclockers.co.uk/showproduct.php?prodid=CD-140-SA&groupid=701&catid=10&subcat=
Graphics Card - Palit GeForce GTX 570 1280MB GDDR5 PCI-Express
http://www.overclockers.co.uk/showproduct.php?prodid=GX-008-PL&groupid=701&catid=56&subcat=1010
PSU - Corsair CX 500W ATX Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-034-CS
Cooling - Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-AR&groupid=701&catid=57&subcat=
Case - Coolermaster CM-690 II Advanced Dominator Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-196-CM
I am really new to this so I dont even know if it will all fit into that case and if that power supply is a high enough wattage?
Any help/advice/different part recommendations would be appreciated thanks
