First Build! :D
Sorry mate having some problems with my camera,So i may aswell tell you now and upload a picture when i can figure out a fix,It's a Q6600 + MSI MS-7360 not sure how good the board is,but cant complain for free :)
So here we go ram update:D
Corsair xms2 extreme performance 4gb i got them for £30 with shipping
Granted they are used but not to old they are about 2 months old if that he said on the listing:D
pc2-6400 and cas latency 5
Latency Timings: CL5 ( 5-5-5-18 )
It will be worth holding out for a quad, especially for FSX and BF3, make sure you get a joystick FSX doesn't play too good with the keyboard :D
Bought many more fans yet luke? lol. I can't judge I have 5 in mine, 7 if you include gpu & psu. :D
Ok will do :D
No not yet roughly if i get fans on the psu,gfx and i will have on the cpu cooler i will have 8 fans in total.
We have a wood burner in our dining room that we use in winter and it heats the house very good and every room is roasting, So i thought with me playing games and how warm it gets in winter in our house i thought i better equip it.:D:D:D
I also have a fan that goes on to the pci ports, i will get a pic up, it is an exhaust fan realy but with that hot air rises i don't think it would do any good:rolleyes::rolleyes:
best keep the window open in winter then, no point having 8 fans blowing intense wood burner heat through the case :D
having said that, a good airflow in the case can drastically lower the temps, load and idle of the major components, a good airflow case can get away with fanless coolers on the cpu & gpu, not that I would recommend spending the rather large amounts of cash on those coolers. and besides that they are usually quite large.
Im already freezing as it is, so opening windows is a no..no:p
I will take a pic of the fan unit i am on about :D
So i have an update with pics, There is a few so be patient:p
SORRY ABOUT SOME OF THE BLURRY PICS:rolleyes:
Any way i have got my fans and cpu cooler:D:D:D
I have put the P4 in to see what room i have with the fans :o
There is about 1mm gap if that lol:cool::D
The copper pipes on the freezer 7 pro rev.2 look to be bent what do you wreckon, as i have looked at images on the net and they are all the same????:confused::confused:
I have posted a pic of that pci slot fan as well.
I am also out of fan screws im missing 1 of the exhaust:mad: Every other fan has 2 diagonally accross from each other.
I have had a couple of reviews say about the cooler as well that the pre-applied thermal paste is abit rubbish, so atleast i atleast get to use the pre-applied paste, then i can use the arctic silver 5 on the quad:D:D:D
Also it will be abit now for the quad and psu and Gfx card as i need to save up for a few things ;);)
So some pics::::D:D:D
Hiper clear exhaust fan:D 120mm fan
RED L.E.D cooler master 120mm fan:D:D
Arctic cooling Freezer 7 Pro rev.2:D That fan is tiny:D
Are the copper cooling pipes crushed???
Sorted the fans out side fans intake, front intake, bottom not decided, rear exhaust:D
1 screw short:mad:
FANS INSIDE IN SITU
Cpu cooler is very close to the fan (Blurry pic sorry)
Pci fan exhaust
Cheers Luke
p.s let me know about the fans, cpu cooler etc as mentioned :D:D:D
Not sure about the fans,Though aslong as they do the job who cares :) I can vouch for the cpu cooler though,It served me well for a long time :)
Lol sorry for my post, i was tired at the time and managed to word it completely wrong -.-
I just meant to seeing the new pics, i love pics :P
And I like the cooler ;)
