First Build/ First O/C (e5200)
14 Jul 2008
Behind you
Sup guys!
Recently built a new PC (well a large upgrade to my old one)
Here is the spec :
Artic Cooling Freezer Pro 7
Geil Value 2x1gig 800Mhz ram
e5200 Pentium Dual Core (sheer awesomeness)
Gigabyte P31 - S3G*
Radeon 4850 GPU
ColorsIT 500W PSU (CRAP)
*Wrong mobo sent out to me from amazon seller but I might stick with it as I was happy with 3.5GHz out of the e5200 in the first place and really cannot be doing with the hassle. Do you think I should send it back - any specific reasons?
And also if I did send it back under what circumstances will I be able to get a full refund (I have pictures of it just out of packaging and the order specifically says P31 - DS3L on the title)
Anyways I have successfully clocked it to 3.5Ghz here is the proof pic :
http://flickcabin.com/public/view/full/5661
(sorry its a random img hosting site tinypic is playing up)
First ever O/C so just point out anything you think thats not right. Im going to leave orthos running for a few more hours tonight... Do the load temps of around 60c look okay?
I also have one question. Does lowering the multiplier effect the the o/c in any way (make it less likely to work etc)?
I know I can have an fsb of upto 400Mhz but I doubt ill ever run at that due to temps.
Lastly want to thank everybody here for the knowledge to be able to O/C this beast to 3.5Ghz. I am very pleased with it :)
Hello there :)
Looking good m8 ;), nice overclock
Have you tried dropping the multi to 10 and going for 400mhz which should give you 4 ghz and might be a bit easier on the board. Been looking at these for a upgrade from a e2140, i like the bang for your buck cpu's :D
Keep up the good work gonna pop in later and see how your stress test went :)
Hi mate. Right gonna go for a reboot and see what happens. I very much doubt ill get it running at 4Ghz. But its a 1:1 ratio so you never know.
Thanks man!
*QUICK to the reset button* :)
EDIT:
3.5 is as good as life gets for me. 4 wouldn't even post a Logo!
