Wish I'd picked up one of those OCUK mats while they were at £5.99 recently. DOH!
Build seems to be coming along nicely - have you tested that the mobo etc work? I'd recommend that you do BEFORE you install it. It's a pig of a job testing a full rig in situe - well - it is when they don't work. Just make sure you fire it up with the basics to make sure it all posts ok
That is if you haven;t already...
Yep, that's why I built it out of the box first. No way was I going through the whole build to find a problem and have to take it all apart. Everything works well though, I'm all booted into windows and am just getting everything sorted and what-not so I can get to using the bloody thing!
Looking good there! Especially the motherboard and memory combination
Good choice with the Asus DG. Great card for the money. Swapped out my X-Fi for the DG as I didn't like the bloated Creative drivers and it caused my PC to take 3-4 times as long to boot as it took ages at the Windows logo stage. Reckon you'll be hooked on PC gaming once you get the 660Ti
I had to have the matching memory, I just couldn't resist! Thanks for the heads up with the GPU and sound card, I'm looking forward to grabbing those bits later down the line!
Right, here it is. All completed and booted! Sorry there aren't photos of the actual build. I was short on time as I had to get work done yesterday, and was away in the evening. So I'll try and talk you through it as best as I can, picking up on some things I encountered along the way, etc.
Firstly, here's my old cable management. Now, I said yesterday that it was driving me crazy it being in the state it was in. So once I'd finished up with teverything yesterday evening (and before Armageddon got to the really sad bit, please don't judge me!) I decided to sort the cables out and head off to bed. I just couldn't go to sleep knowing I'd left it in such a state, and I just didn't know when I'd get around to sorting it.
I think you'll agree, this is pretty bad. Wires crossed over, wrapped around each other, in the wrong place. Not good enough.
Now, here it is after I sorted it as best I could. The only thing I have to say about this is SATA power cables. If it weren't for the ones supplied with the PSU being just a little too short, and having the actual connectors upside down, for now I'd have only needed the one. But, since that was the case, I had to use two. Made the job a little harder, but I got it sorted in the end.
I have sort of cheated and tucked some of the cables away in the HDD area for now, as there isn't really anywhere to tie them to in that area. Perhaps when I get to add my HDD and GPU, I'll do it all over again but for now I'm happy with this. The side panel goes on, it doesn't bulge out and that's good enough for me.
Here's the inside of the case. It's a little dark so I hope you can see everything. The cables at the bottom are a little messy, as I can't for the life of me find where to connect the power LED on the adapter(s) provided, but I'll sort it don't worry.
You can see the fans for the H100i in the top, and if you look how close they are to the rear exhaust fan, you'll see why the radiator had to be mounted the opposite way I would have liked. There just isn't room for the tubing and both fans. It'd be even worse if I had to mount the radiator in the same area as the motherboard as the massive heatsinks on the MPower simply eat up all the room.
Another problem the heatsinks caused me was the screw heads under the board itself. As the Bitfenix Ghost has raised mounds for the motherboard to rest on eliminating the need for stand offs, there was one screw stopping the motherboard from sitting flat in the case. To sort this, I simply had to rejig things a little, make sure everything was fully lined up and then get it screwed in as even as I could. There is very minimal flex (if any actually) and since the motherboard is a little thicker than others, it should take it just fine. I've encountered no problems so far, so let's just hope it stays that way.
The radiator is held in place by the fans below, hence there being no screws in the top. It's perfectly secure don't worry. But the heatsinks on the motherboard didn't half make it difficult to get the fans screwed in! All is well though, and I didn't have to mount it inside the case so I've no complaints here! There is plenty of space in the room for the radiator, but as I mentioned above - Be cautious of which direction you have your tubing, because it's a really tight squeeze with all those fans in there!
That's it for pictures I'm afraid. Like I said, I wish I could have photographed or filmed it step by step but there was just no time.
I'm yet to dive into overclocking and benchmarking, if I choose to do so. I dare say I'll overclock, but I'm not really into benchmarks to be honest. I can however confirm that at stock clocks the H100i is keeping the system at 27-32C when idle/light use. And since I've not been running any tests or using heavy applications I can't comment how it performs under load. However, that seems like a pretty good result to me, and do bear in mind the case does have sound absorbing material, and not all that much of a front intake (If it makes any difference that is).
I hope you've enjoyed my progress! I can honestly say apart from all the swearing, and catching myself on the case and what-not, it's been a very enjoyable experience that I hope I can repeat in the future.
Thanks a lot,
- Anthony.
