First Build
It's all good thought I broke it.just a quick question where do the hxt and vdg cables go
What kind of thing do these cables come from?
A google suggests they relate to RGB, but you have to be careful with these, to make sure you don't use the wrong header.
Where is the model number located.if you need to know what case it is its the kolink citadel mesh rgb micro-atx case-black
It says you can control the RGB either with the remote supplied, or by connecting the cable to a compatible 3-pin ARGB header on the motherboard.
I don't know if your motherboard has any of these. The manual doesn't say if the connector is 12v or 5v.
Motherboard is msi b550m pro vdh wifi
I can't tell from the manual. I think you have to match the ARGB voltage, because they can be 12v or 5v. From what I can gather, both 3 and 4 pin headers have 4 "pins", but the 3 pin (5v) only has 3 wires. I don't feel confident enough to tell you and if you get it wrong, it is not good.
Do I need to use pcie 5.0 on the power supply
No but it mite be wise to get one (atx 3.0) otherwise you need to use an adapter for Nvidia cards which usually comes with the new GPU if you don't.
Atx 3.0 power supply is the new standard and come with the 12 pin connector for Nvidia latest cards, they also have enough 8 pin connectors for AMD cards .
Think the RGB fans are non standard and have to use the Kolink controller on the back of the motherboard tray.
This video explains more at ~ 13.50
Think the USB2/AUDIO cable can be seperated a bit more to reach the sockets. It is just a ribbon cable, so just carefully pull the wires apart to the required length.
This video shows the cables at ~ 10.08 but is not in english.
