First Build
So I've plugged everything into my PC but nothing happens anyone got any ideas of what it could be
If you get no fans and literally nothing, then it's likely to be either the case front panel connectors (i.e. power switch), or the power connectors to the motherboard. You should also check the rear PSU switch is set to ON.
