- 26 Oct 2017
So basically I want a good steady 60fps on ultra quality. I have £1200 to spend, I need a Mech Keyboard, Mouse (Preferably a MMO Mouse), Monitor, all the parts, Case etc etc.
You don't spend 1200 and put an i3 in a system that's just wrong. Ryzen or coffee lake i5 upwards is the way to go.
Maybe lower ssd to 250gb and put towards a mechanical drive and towards a higher intel cpu if you go intel
Regarding mechanical keyboards are they something you have used before? If not try some first they do vary allot.
I just think if spending 1200 on a system I'd want more than the entry cpu, I'd be getting 6 core as a minimum now and that would apply to me if I was about to drop 1200. Weather that's amd or intel would depend on performance reviews I'm not biased to eitheri3 is now i5..... Or you on about you don't out a 4 core i3 in a £1200 system with screen in the bundle but i5 6 core instead...
Stigma of Intel right there
With monitor and other peripherals it makes it harder, though. Windows isn't even included in above specs. Crazy RAM prices don't help, either. On the plus side, the i3-8350K is identical to the i5-7600K in your sig, much cheaper, and on a platform that can take the six core upgrade.
Good find, altered my recommended build to include that bundle.
