He's found some pins and is now piecing together an effigy of the person who suggested a breeze block to cool his CPU
He's probably redressing the cuts on his hands after moving his memory with everything in the case...
No, use both - the hard wired and the one you had to connect to the PSU. You require two independent cables to power that card.Also, sorry but you've lost me with regards to the PCI power cables. Am I to disconnect the independent cable that was in the box and just us the one hard wired to the PSU?
PSU hard wired cable -------------------> PCIE --> GPU
spare connector flopping about (then neatly zip tied)
PSU manually connected cable -------------------> PCIE --> GPU
spare connector flopping about (also then neatly zip tied)
doesn't matter. the cables are 6+2 pins. so for the 8 pin connector, all 8 pins are connectedWhich cable for each or does it not matter?
imgur is your best friendTrying to work out how to get pictures on here.
A2B2 is correct.bios is telling me to change back to B2 and A2 for best performance?
Yep, cable length very obvious in pics - even when fuzzy \o/is that what she said?
LOL
To be fair to you - your manual gave you both options.I'm going to have to move this damn fan on the cooler once again to move the ram!!![]()
CPU -> blank ram slot -> ram -> blank slot -> ram
I'll post him my old Silver Arrow, which i use as a shelf ornament in my study, he'll soon stop complaining.ikr. bloody joker speccing a 1kg lump of metal. sigh.
Try one stick of memory - remove A2.Back to no display!
