can't be ruled out unless we know it's working properly...lol...It will be a p***er if he's got himself a double whammy. :/
On the plus side I'm getting pretty good at replacing the fan on the cooler now![]()
short term pain for long term gain![]()
haha thanks guys running the second test now. No errors yet!
You realise @tamzzy is hoping for zero errors as it will completely vindicate the 'Arthur C Clarke Monolith' strapped to your CPU![]()
It'll pass - board warping was a long shot with that cooler. It's got a relatively simple fitting for its size.Ha well i'm hoping for no errors too otherwise i'm going to have to remove the damn thing![]()
Hah! You got meYou realise @tamzzy is hoping for zero errors as it will completely vindicate the 'Arthur C Clarke Monolith' strapped to your CPU![]()
But you know what they say about big ones...![]()
Well, you know they work/compatible...No I went Intel I7-9700K
Thanks, I'll just order the same again
The company I got the ram from (rymes with scam) want 3-5 working days on receipt to organise a replacement. I'm not overly happy about this so have requested a refund and will take my business elsewhere. Is this still the best ram to get?
For what it’s worth, this is normal business practice.
I buy absolutely everything I can from OcUK, good prices, top service.
I also wrongly assumed the motherboard would have wifi built in. Any recommendations as to which wifi card to get?
Few motherboards do these days. For the most part it’s reserved for ITX and high end boards. My Maximus X Formula has it, but I don’t use it.
I would strongly recommend wired Ethernet, but if you can’t, I used the Netgear AC1200 (A6210) and was very impressed. It’s a USB dongle rather than a PCI-E card though.
Something like this from OCUK would be good, there are higher end versions with external antennas available too : https://www.overclockers.co.uk/asus...-pci-e-adapter-90ig00k0-bm0000-nw-088-as.html
Thanks, I don't have any ethernet sockets in the house unfortunately. I was also considering those powerline adapters but heard mixed reviews. The only other option would be mesh wifi but that's much more expensive.
