not too sure if physical media is worth £100I prefer physical media in my hands, so would likely shell out for a retail copy.
i suspect, as OP is still using DVR for now, and PP later on, that i9+2080 is the best all-rounder package for himreally all depends on what programs your using ... i9 + 2080 is the all round package
@Nicholas Sorrell food for thought. https://www.4kshooters.net/2018/03/25/can-an-nvme-drive-really-enhance-your-video-editing-workflow/
this guy uses NVME SSD for scratch disk, SATA3 SSD for export disk, and normal hdd (RAID1 probably) for backup.
based on the above, how's about this:
My basket at Overclockers UK:
- 1 x Intel Core i9-9900K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM= £469.99
- 1 x Gigabyte Z390 Aorus Elite Intel Z390 (Socket 1151) DDR4 ATX Motherboard= £179.99
- 2 x Team Group Vulcan T-Force 32GB (2x16GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD432G3= 2 x £179.99
- 1 x Corsair RMx 750w 80 Plus Gold Modular Power Supply (CP-9020179-UK)= £94.99
- 1 x MSI GeForce RTX 2080 Ventus 8192MB GDDR6 PCI-Express Graphics Card= £638.99
- 1 x Samsung 970 EVO Polaris 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive= £109.99
- 1 x Samsung 1TB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E1T0B/EU)= £139.99
- 2 x Seagate 4TB BarraCuda PRO 7200RPM 128MB Cache Internal Hard Drive (ST4000DM006)= 2 x £152.99
- 1 x be quiet! Dark Rock Pro 4 CPU Cooler= £73.99
- 1 x NZXT H500 Midi Tower Gaming Case - Black Window= £74.99
- 2 x Arctic Cooling F14 Fan - 140mm= 2 x £4.99
- 1 x Corsair Gaming K55 + HARPOON RGB Gaming Keyboard and Mouse Combo= £74.99
- 1 x Microsoft Windows 10 Pro 64-Bit DVD - OEM (MS-FQC-08929)= £149.99
1) storage combination: 500gb nvme ssd (scratch disk), 1tb sata3 ssd (export disk), 2x 4tb hdd in raid 1 (backup storage)
2) changed the case around, also added 2x 140mm fans for the front (case only comes with rear fans).
3) i've added windows too. unfortunately you seem like the guy who wants a computer to "just work" as soon as it hits the doorstep. with the storage array as above, it'll need to be set up in bios, and will need to make sure it works in windows, so better to get the techs to do it for you
I've got much to think about and it has prompted yet more research
