First time eyefinity, not going to well....
20 Feb 2009
Perthshire
Hey Guys,
I have just purchased another two monitors to run an eyefinity setup with my x-fired 5870's. It hasn't exactly gone the way i'd hoped for tho. I purchased a DP to VGA adapter that seems to be working fine and have followed the video's on youtube to set up the group so that I can get full resolution of 6114 x 1152 ( 3x Dell SP2309W @ 2048 x 1152 ) I have the windows toolbar / desktop spanned across all 3 monitors and working.
The first game I tried out was Dirt2 and it ran perfectly when I started it up, I had to turn gfx down a little bit from ultra to high but it looked great and had fine fps for playing. All was well or so I thought until I tired a few other games.....
BFBC2 : CRASH
L4D2 : CRASH AFTER INTO
WIC : SCREEN WAS MOSTLY BLACK AND COULD HARDLY MAKE OUT ANYTHING
METRO 2033 : ENABLE HIGH RES AND SCREEN FLASHES LIKE MAD
I have also have BSOD with an error saying something about ATIKPAG on two occasions.
This is on a fresh install of Win7 x64 with ATI 10.8 Drivers
Unfortunately the displays will not fit on my current desk but have a bigger one order and should get tomorrow or the next day so setup has been done on livingroom floor.
If anyone could give me some help it would be greatly appreciated.
Thanks,
Kev
I generally haven't like any newer ati drivers since 1.5 but I guessed the newest ones would have more for eyefinity so ran with them, good suggestion tho, that will probably be the first thing I try out tomorrow. Back to the old trusty 10.4as or 10.5s. I have moved back to one monitor now on desk as too awkward doing all this on the floor.
I found exactly the same thing but was much more stable on 10.4a drivers. Eyefinity is still an infant technology and coupling it with crossfire is double trouble.
U should be able to ultra on dirt 2 but put post processing down to medium. BC2 will run max @4xAA. I'm getting rid of crossfire cos it's just too warm in the room and hella noisy.
Thanks very much guys ! I had thought it would have been a software issue. I should get my desk tonight so will set it all up properly and install the 10.4a drivers !
bezel management is also a great feature for gaming, unfortunately u need to change the profile if want to turn it off for desktop use.
Hey guys,
I got my desk and have everything up and running but i'm having major problems with Eyefinity and X-fire, really not sure where to go from here.
I belive the problem is probably with drivers, If I install 10.8 I can enable crossfire and run eyefinity. However the only game that works is Dirt2. L4D crashes before main menu, metro 2033 the game loads but all screens flash and lag to the point where it is unplayable. Arma 2 same sort of thing, black screen that flashes the game.
If I install 10.5 or 10.4a I have to disable crossfire and only then will it give me the option to set up a display group for eyefinity. With crossfire enabled there is not option.
I know eyefinty works on my setup with the DP - VGA adapter.
All monitors connected to first card, have swaped cards around, cleared cmos but all to no avail.
Can someone help please ?
Kev
I have 10.5s installed right now with the 10.8a profiles, still no option to set up display group with crossfire enabled. I can get the display group option only when crossfire is disabled. Then when enabled it turns off eyefinity.
I'm rather annoyed as 10.8s will let me enable eyefinity with x-frie but the games don't work :(
This is setup though 2x dvi 1x displayport to vga adapter.
Try 10.6/10.7 and see when the functionality was introduced? Alternatively try stepping back 10.4 and see if its just a glitch with 10.5's CCC?
(Actually you could try installing the 10.8 CCC and profiles, but not the 10.8 driver (stick with 10.5) and see if that fixes it too...)
Well not getting v far with this. Have tried 10.4a & 10.5s with x-fire profiles but not working. I'm gonna try putting in a DVI + HDMI + DP, if that don't work then i'm gonna try 10.6 - 10.7 - 10.8, not really happy using those drivers tho as messed up xfire even on a single monitor.
Tried new CCC + 10.5, still same, about to try 10.6, thanks for the advice tho. Can't plug in hdmi as the adapter stops it from fitting :(
Getting eyefinity working now with newer drivers. However all the screens flash like hell and don't know how to fix this. If running with crossfire disabled there is no flashing. Getting close just need to get this flickering sorted and should be ready to rock. Any ideas ?
Well flashed the bios to a newer ati one. It's all now working now but i'm not happy with it at all. ON bfbc2 the fps are around 30 wiht crossfire enabled and around 40 with it disabled. I am running the latest 10.8 with 10.8a profiles. Steam games such as L4D2 and CSS won't run on crossfire at all. The screens just contactly flash. This is the same for Arma 2. Anyone else here running x-fired eyefinity that could post there set-up plus the fps they get on bfbc2 and if steam games actully work with x fire. Starting to think this was just a waste of money.
