- 23 Dec 2009
hi im new to this overclocking game just got a few questions
1)can i do any dameage to the cpu if i reduce the voltage on an over clock?
iv set the bus speed to 100mhz and over clocked the cpu e6750 to 3gh from 2.66 i droped the voltage down a bit to ?
what do i have to do to the memory i read a lot of you guys say the memory has to be set to 1:1 when you look at it in cpu z mine says FSB VS DRAM 5:6 should i be bothered with that if what i have done so far works? will it make memory performance worse
thanks
thanks
