First Time Overclocking - Problem
8 Apr 2012
HI Guys
Just bought this setup:
i5 2500k
Gigabyte Z77X-D3H motherboard
Samsung Green 16GB RAM
When I try overclocking to anything above stock it freezes or I get a BSOD as soon as Windows loads up, I can't even get to run Prime.
I've tried OCing to 4ghz, 4.2ghz, 4.4ghz and get an error every time, have tried changing the VCore to between 1.30 and 1.4 and the VTT from 1.05 - 1.20 and can't find a stable setup even to boot into Windows unless it is in safe mode.
Managed to get a error dump in safe mode.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 2057
Additional information about the problem:
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA800D0FC028
BCP3: 00000000BE200000
BCP4: 000000000005110A
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Any help or suggestions would be welcomed.
0x00000124 generally means a lack of Vcore.
From stock volts (so Vcore on auto) just raise multiplier from x34 one step at a time until it no longer boots into windows, then raise Vcore until you get a boot etc with different mutipliers, this should really work up to about 4.2ghz or maybe even 4.5 ghz if you have a good chip! :rolleyes:
OK, ran Prime95 for 8 hours at stock and one of the cores had an error.
Had the following error on Core 3:
FATAL ERROR: Rounding was 2.213541735e+020, expected less than 0.4.
So, 1 error in 8 hours...does this mean my CPU is knackered? Would explain why an OC fails everytime I guess if it can't even stress at stock. :(
Can I return this for a replacement or is there some weird tolerance disclaimer from Intel?
**edit - moved this to CPU section
