final update for now unless i get any more issues
Changing PCIe lanes to 2.0 , HPET enabled in bios (Might not be enabled in OS though need to check that) and CPU at 4.6ghz again.. Bioshock doesn't seem to be crashing! Have not managed to get on BF4 yet but hopefully that will work as well.
GPU usage in farcry3 and Bioshock infinite is in the 90% range usually around 95-99%
To combat the heat I have dropped the memory overclocks on both cards to stock till I can get some solution figured out Top card is hitting 70c and throttling slightly but its a non issue and the twins look beautiful together, I can see why some people said SLI is a bit of a headache but worth it once your up and running (Maxing far cry 3 and 80-100fps scene depending, 1 card could only manage 45-59)
Thanks for all the help everyone![]()
Yup, when I just read the thread for the first time my initial thought was 'expect heat!'.
My top GPU is hitting 79 after a few mins of gaming and throttling constantly, it should be up at 1180 and is coming down to the low 1000's.
I've never had an issue with SLI, all games over the past few years seem to work fine.
Surround is another story, but even then, you can still get most games over the past couple of years to work.
If you figure out a good way of keeping the top one cool let me know!
Most people put a 120 on the end of them but I don't have room for that so I have sat one in the HDD bay - not really any better.
I'm disappointed with the scaling though, I heard they scale up to 80% but in the couple of benches I have done it looks to be more in the 60's.
Cheers,
sounds like it wasn't too painful, nice - shame about the throttling, hope the fans work out (sounds like they should)
