hi guys,
I'm planning on building my first loop (cpu only) and I don't really know what to get. my budget would be £170 maximum (less would be way better though) and i've had a look at these kits:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-265-XS&groupid=962&catid=1532
http://www.overclockers.co.uk/showproduct.php?prodid=WC-020-TL&groupid=962&catid=1532
http://www.overclockers.co.uk/showproduct.php?prodid=WC-234-XS&groupid=962&catid=1532
what do you guys think? I've got a fx8350 that's currently at 4.4ghz but anything higher (even at stock voltage) gets the temperatures too high.
thanks
Jimmy
edit: or would i be better off just getting a better air cooler? my case is a nzxt phantom enthusiat and i don't have a side window
thanks
Jimmy
that comes pre fitted with a reservoir as well
