Fish pond advice
Bony Maloney said:
I like pump----->UV filter---->Marshmule2000 filter system---->pond :)
That's what you want :) My grandad made a customised filter a while back which consisyed of two big black plastic boxes, one full of matting, the other one full of brushes suspended on garden canes. The pond water was then syphened into the filter, first into the brushes then into the matting, then pumped into the UV light and finally into the pond. One of the best filter systems I've seen, it kept the water really clear and they were so easy to maintain.
Good Luck with your project though, keep us posted :cool:
ours has those hedgehog filter things (look like big bottle cleaners) then though to a gravley type one, the UV filters first.
Yeah, that's what these were, I just couldn't describe them properly :o Works very well though :)
have to be cleaned out once in a while tho, ours where EVIL when we did it.
Our pond is having a problem with blanket weed at the moment due to all the sunshine. Doesnt really matter if you have a UV filter or not, in this weather stuff will still grow.
All I can do to keep it under control is regular cleaning of the filter, keep treating it every 4 weeks or so with additives, and fish out any weed a few times a week. We also bought some bottom dwellers which stay around the bottom of the pond and feed on the weed and other crap.
Water itself is crystal clear though.
All I can do to keep it under control is regular cleaning of the filter, keep treating it every 4 weeks or so with additives, and fish out any weed a few times a week. We also bought some 'weather roach' which stay around the bottom of the pond and feed on the weed and other crap.
tbh theres this floating plant you can get that coveres it
Nismo said:
Get a goddamn portable sun then! :p
No problem, our pond will be fine anyway. Just need to keep on top of it.
its like realy small, 1cm across and multiplys like MAD, got roots down into the water. kinda brown/green etc
I've probably seen it before, or possibly even tried some in the past.
Were doing a pretty good job without the need for plants anyway, its only the recent strong sunshine that has brought the blanket weed about.
Just buy a new tube for the UV and you should be sorted. With my father in law's Koi pond I can always tell when it is time for a replacement tube as you get the bright green pea soup. 10 days after changing everything is clear again.
I used to make my own filters out of black plastic dustbins and black polypipe for the tubing and used the green coloured nylon greenhouse shading as the filter media. A big surface area for the microbes to live on and as it was arranged in 2.0 metre lengths it was quite easy to wash out.
PeterT
We use Nishikoi Goodbye Blanket Weed with Activated Barley Straw. Comes in 25g sachets. Its not cheap but certainly does the job better than anything else we've tried. We don't have any algae or blanket weed.. but then again our Koi eat quite a lot of it when it grows anyway!
What type of filter do you have? You shouldn't have to clean it that often.. it's needs the bacteria to help clean the water. Also if you're adding tap water to top it up this time of year make sure you treat it.
our pond is in full sun but has no blanket weed this year. We put in plenty of oxygenators and some duckweed to use up all the nutrients before the blanket weed gets growing and it's cured the problem. Plus the duckweed is a lot easier to scoop off when it gets rampant than blanketweed.
Hows is your filter made up? Is it just one section or in several sections
We have a 1500 gallon pond with the pump going through a UV filter then into a 3 section filter.
Ours is made of the first section is a set of brushed this then spills over the devide into the second section onto several foam layers starting with a very coarse one and getting to a fine on.
After that it flows over no idea what its called but bits of plastic for the bacteria to grow on then into the pond.
Also why do you clean it out every day?
Nikumba
Does anybody know of any fish that actually feed on I guess what is "waste product" in the bottom of ponds?
We have an outside pond, we inherited it with the house.
We've spent a fair amount of time and money on it and we've got a good quality pump and filter system.
There is now no blanket weed left and the water that flows out of the pump and down the waterfall I built is almost toally clear.
The water in the pond is also clear, however there is a layer of "green silt" accross the bottom of the pond.
This unfortunately gives the impression the pond isn't that clear.
Also as the fish swim low they "flip up" the green silt from the bottom.
We've added some new foliage to the pond.
We are also using a product called "Sludge Buster" which apparently breaks down this green layer at the bottom of the pond over time and eventually all should be clear.
However if there is a fish out that actually actively feeds off of this stuff accross the bottom of the pond it would be worth us introducing a couple as they will have a field day in our pond :)
Weather loachs are one variety of bottom dweller that will feed on the crap at the bottom :)
My 11 Koi Carp are like hoovers, they move along the bottom hoovering up everything from little stones to the "waste products" and they only spit out the stones. Ah well.. what ever keeps them happy. They've only started doing this over the past few years, really since they've been about a foot long. Wierd eh!
We've got a 1000 gallon pond with a bottom drain so a lot of the rubbish gets sucked out the bottom. This feeds the 3 part filter, the pump is attached to that and sends the water through a UV filter which then via a stream ends up back in the pond. Some nifty piperwork in there :D
