Not necessarily. Certain of those mods can look very good on particular cars. But there is a time and place... (which is often ignored in a max power/ripspeed induced frenzyEnfield said:Window film
seat covers
door pins
fuel cap
pedals
mesh
Max Power 4tl
emailiscrap said:Certain of those mods can look very good on particular cars.
Sticker or real?Vicious said:hmm lol i think petrol caps are ok, ive just fitted mine and it looks better than stock
manc said:The door pins unscrew with a 40s torx socket and then tap the rest of the way out, no need to strip the door. Make sure the top hinge hasnt come unwelded - its a common problem on 106's and I have welded them back on under warranty for peugeot in the past on cars under 3 years old, the pins dont usually fail on there own.
GT3 said:Prove it![]()
