In the end I pulled it all down and ordered 20 20mm marmox boards to board three of the walls. two walls are outside walls so should help keep the room warmer. The stud wall was 20mm deep so wanted to make it easier to line up with the door frame.
Re did the stud as one was warped, adding noggins for the shower frame. Room wasn't 100% square so the board on the brick wall go onto the shower, stud wall butts up to the base. Then used silicon to seal the gaps. I have a mapei tanking kit to fully waterproof it.
As it is now, wiring and feed for electric shower. 'Plural of dab'(avoiding the competitor filter) of adhesive are in position behind the wall for the shower and rail fittings so hope to have no issues fitting. I used to dot and dab method as the wall wasn't completely true.
Today ill be boarding the rest of the room -hopefully the window area will be ok. Give me chance to use a smaller window trim too
