@ Techen.
Your CPU is the problem in BF4 with DX.
To give you an example.
R9 290
BF4 Shanghai: Ultra Preset 1080P
DirectX
Min 48, Max 97, Avg 65.158
Mantle
Min 68, Max 116, Avg 94.082
Put simply the difference in performance between DX and Mantle is huge.
So a upgrade in CPU is needed?
No, its not needed. I'm running a 4 year old AMD Phenom II x6.
In DX i get huge CPU bottlenecks, it can go as low as 40 FPS because the CPU is holding the GPU back.
In Mantle that does not happen, thats the whole point of Mantle, it removes the CPU bottleneck, even on weaker CPU's, with Mantle my old AMD CPU never ever holds my R9 290 back.
Your i5 is plenty powerful, if you use Mantle.
Youll notice that the photo is my computer running mantle with huge cpu spikes that freeze the entire game every minute
Your cpu most certainly isn't the problem; from what I can gather, BF4 has had its fair share of problems. Even without mantle, your cpu should be fine.
Am honestly so tempted to RMA or Sell the 290x and grab a 780TI just because of the new updated drivers and extra power.... Disappointed in AMDs slow reactions in fixing mantle, along with lack of games that support it.
It only happens every so often, Small squares on the screen. When I run a window over them they go.
Should I still ask for a RMA?
After owning both, if you were to swap out your 290X for a 780Ti you'd see no improvement in fps, this i'm certain of, the 290X is just as quick as the 780Ti in bf4 at 1080P and even more so at 1440P.
Definitely use Mantle and overclock your CPU and that 290X.
Sorry but the 780Ti is faster than the 290X, so he would see an improvement in fps.
 , i said in BF4 a 290X is just as quick as 780Ti.
, i said in BF4 a 290X is just as quick as 780Ti.I didn't say the 290X was faster the the 780Ti Greg, i said in BF4 a 290X is just as quick as 780Ti.
