Flash Drive Slash
22 Apr 2014
I will be doing some price slashing on the Corsair Flash memory drives this weekend so keep checking the site for more updates. They will be going back up Monday afternoon so be quick. Some small capacity and large capacity going under the knife.
Here are a couple of examples.
Corsair Flash Voyager GT 256GB USB 3.0 Flash Drive (CMFVYGT3B-256GB) @ £129.98 inc VAT
- High Performance with USB 3.0 or USB 2.0
- Durable rubber housing
- Water resistant
- Shock proof
- Limited 5 year warranty
The Flash Voyager GT USB 3.0 really takes advantage of the performance of USB 3.0, with up to 8x the speed of a typical USB 2.0 flash drive. But even when used on a USB 2.0 port it’s one of the fastest drives on the market. The unique all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data. Just plug it in and it works, with Windows, Mac OS X and even Linux. The Flash Voyager GT USB 3.0 is backed by Corsair, a respected name with a passion for quality and customer service.
Was £159.99 Inc. VAT
Only £129.98 inc VAT.
Corsair Flash Voyager GT 128GB USB 3.0 Flash Drive (CMFVYGT3B-128GB) @ £69.98 inc VAT
- Water resistant
- Shock proof
Was £89.99 Inc. VAT
Only £69.98 inc VAT.
Corsair Flash Voyager GO 64GB OTG Flash Drive (CMFVG-64GB-EU) @ £19.99 inc VAT
- Allows you to move and copy files between your Android device and your desktop/notebook PC without using a bulky cable
- Works with any USB On-The-Go compatible Android tablet or smartphone with a Micro-USB connector
- Dramatically boosts your mobile device¡¦s storage capacity
- USB 3.0 speed with USB 2.0 compatibility
- Plug and Play, with no driver or app necessary
- Includes extra caps and a lanyard for a personalized look and handy access - Compatible with Windows 8, Windows 7, Windows Vista, Windows XP, Mac OS, Linux
Imagine no more emailing photos to yourself, hunting for a USB cable, or running out of room on your USB On-The-Go compatible Android phone or tablet. Flash Voyager GO is the quick and easy way to move photos, music and videos between your mobile devices and your PCs and dramatically increase your devices’ storage. The ingenious design has both a USB and a Micro-USB connector, so you can copy photos and videos to your desktop or notebook PC for safekeeping, share music and media between your PCs and your Android device, or just leave it connected to the Micro-USB port for a huge boost to your device’s storage capacity.
Was £39.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Corsair Flash Voyager MINI USB 3.0 64GB (CMFMINI3-64GB) @ £19.99 inc VAT
Flash Voyager Mini USB 3.0 is the tiny USB flash drive with full-size USB 3.0 performance. The USB 3.0 connector allows for optimal file transfer speed with the latest systems, and it’s fully compatible with USB 2.0. It comes with a detachable loop for attaching to your key ring, and the durable brushed metal housing resists wear and tear.
• USB 3.0 performance (compatible with USB 2.0)
• Compact aluminum housing
• Durable rubber strap and ring for convenient key-ring use
• Limited 5 year warranty
Was £36.99 Inc. VAT
ORDER NOW
