Floppy Drive keeps beeping
Permabanned
5 Dec 2004
South West
Hey, i've just installed my new x1950 pro and everything is fine except for my floppy drive keeps doing that beeping thing. The light goes green every few seconsd, makes its sound, then stops.
I'll disconnect it if I can't find a solution but i'm thinking this might be something to do with power.
What do you guys think?
Norton Anti-Virus has had this problem for years! You can turn off scan floppy drive/removable devices on boot/shutdown but it is one of those problems that doesn't seem to always occur. no one seems to have the answer to it and there is more than one cause posted on forums. :confused:
it could be either ive had both problems.. the best fix is take it out u only need them for sata drivers ect now
