Folding@home News 24th September - 1st October
14 Apr 2009
24 September - 01 October 2015
Properly formatted version click here
Total members: 2,635
Active members: 43
# Name Weekly Increase
1 Biffa 7,039,371 -893,763
2 currob 3,742,608 134,851
3 Jumper118 3,718,326 -56,178
4 ozaudio 2,908,181 608,772
5 Andy_Taximan 2,857,258 -1,917,169
6 jondi_hanluc 2,350,856 2,350,856
7 Brown_Sparrow 2,216,794 480,542
8 CADmunkey 2,046,292 1,591,099
9 divebod 1,662,201 64,347
10 postmanfw 944,449 944,449
11 acme15 716,187 424,052
12 Senture 289,015 -174,191
13 Team_Muck_Spreader 247,401 -58,297
14 octabrain 214,687 202,579
15 FizzyLogic 196,387 3,430
16 Ken_Harding 146,302 4,557
17 Grumble_D 110,432 0
18 JeroenVanLaer 94,353 -578
19 Pilgrim57 84,683 -40,289
20 RoryM 72,328 19,720
21 Trunkey 64,354 13,756
22 Red_and_White 58,948 1,690
23 Streetlight 46,361 -3,480
24 sphen 34,240 8,061
25 sideburns 30,874 9,313
26 WobblerJW 28,676 28,676
27 drossgraham 28,566 3,328
28 FatRakoon 25,599 11,907
29 Henley 19,559 -2,620
30 GreenGusTech 16,410 16,410
31 davev8 13,657 -356
32 Pedro 12,078 1,986
33 BeeCee 11,623 -112,217
34 bombay121 11,495 -71,941
35 KingDing 7,122 5,242
36 JChirac 6,542 -14
37 Illumielle 2,205 1,584
38 voicon 1,330 -244
39 CheechWizard 1,298 -740
40 Exseanat 1,035 -414
41 Juantjie 720 720
42 SAEID_Persian 470 0
43 Jagman2k 284 -9,460
1 Brown_Sparrow 2,216,794 480,542
2 acme15 716,187 424,052
3 Pilgrim57 84,683 -40,289
4 WobblerJW 28,676 28,676
5 davev8 13,657 -356
# Name Credit
1 Biffa 1,217,938,154
2 Ba 824,880,655
3 loudbob 460,288,801
4 Borged_by_MGP 215,766,536
5 Andy_Taximan 171,970,441
6 Team_Muck_Spreader 118,251,097
7 Stan_Lite 116,570,089
8 Jumper118 115,886,354
9 dekez 56,745,483
10 Bigstan 52,625,969
11 ozaudio 48,433,071
12 mark001282 48,198,874
13 voicon 45,354,052
14 acme15 40,443,702
15 penfold 39,802,359
16 nutnut 35,091,518
17 diogenese 34,329,703
18 Brown_Sparrow 33,719,941
19 snapsh0t_too 27,523,080
20 LigerZero 24,797,360
# Name PPD
1 Biffa 1,005,624
2 currob 534,658
3 Jumper118 531,189
4 ozaudio 415,454
5 Andy_Taximan 408,180
6 jondi_hanluc 335,837
7 Brown_Sparrow 316,685
8 CADmunkey 292,327
9 divebod 237,457
10 postmanfw 134,921
11 acme15 102,312
12 Senture 41,288
13 Team_Muck_Spreader 35,343
14 octabrain 30,670
15 FizzyLogic 28,055
16 Ken_Harding 20,900
17 Grumble_D 15,776
18 JeroenVanLaer 13,479
19 Pilgrim57 12,098
20 RoryM 10,333
A warm welcome to the team :)
100,000
Grumble_D
500,000
JChirac
1,000,000
postmanfw
2,000,000
CADmunkey
JeroenVanLaer
15,000,000
currob
17,000,000
divebod
20,000,000
jondi_hanluc
33,000,000
Brown_Sparrow
40,000,000
acme15
48,000,000
ozaudio
115,000,000
Jumper118
171,000,000
Andy_Taximan
1,217,000,000
Biffa
Help on setting up folding@home:
OcUk F@H Sticky
Stanford Folding@home website
Bigadv guide
F@H Monitoring Programs:
HFM.NET
FahMon
FahSpy
Folding Stats:
EOC Folding Stats
Stanford Stats
Stats sigs:
EOC Stats sigs
Other:
Folding@home server status
News Graphics by Halz - Team OcUK © 2012
Not a great week for me, I forgot to turn off auto updates so the system restarted and sat at the login screen for a week! Turned them off now, need to configure it to auto login as well I think.
as long as your running a single pc it doesn't matter how many gpus you have, as long as its all within one system
Yep so long as you only have 1 PC folding under your username it doesn't matter how many clients, CPUs or GPUs you have running, just say in this thread you want to join and I'll add you for the next weeks news :)
OK cheers guys. Any tips on how to push some more performance on Full load of the SAH client? Even at full its only using around 72% of my gpus available resources according to my monitoring software. Must be someway of squeezing out the rest, maybe these are advanced options within the client itself?
have you set it to full? if your folding on cpu aswell then pause the slot or remove it as NVidia gpus need a cpu core each
right click the folding icon in the tray and select full instead of medium if its not already done so
Yes mate, on full when I can, and I removed cpu when I first joined the group after someone on here mentioned it. Interesting that currob is getting 85%.
I pretty much hit max gpu when 3D rendering so just found it curious that the folding client doesnt seem to max it out properly.
the gpu usage can depend on your cpu and the wu. as nvidia cards only use 1 core, the faster they are clocked to high gpu you should get. i get about the same PPD on my pentium [email protected] with 2 gpus as i did with my i5 2550K@5ghz. also some wu dont seem to max out the gpu, i find that on my 970's core 15's use 99% all the time and make them run around 5-7c hotter than core 18 and 21 which get around 90-95% usage.
