run a 3dmark on both clocks and you will see if it is the case or not
I would , if I knew how
It kicks in when the gpu power isnt needed. For example, as everyone probably know, gears of war has a serious stuttering problem. However, if using an ati card with powerplay, when the game stutters, gpu load goes down and powerplay kicks in. This makes matters worse.
Similarly in crysis, when the game stutters a bit powerplay kicks in making matters a lot worse.
However, as mentioned, using a modified bios or simply using a rivatuner profile with fixed clocks resolves the problem.
Hi HeX
Is there a thread covering the BIOS flash ? Where did you get the BIOS from/ how did you do it ?
thanks
Martin
I followed this:
http://www.xtremesystems.org/forums/showpost.php?p=2782722&postcount=12
Worked a treat![]()
