Fract Engine Benchmark
13 Dec 2003
UK
Fract is a free, open-source PC benchmark based on realtime software rendering. It is designed to provide 100% unbiased results that really correspond to the raw performance of your CPU and system bus; while the test mainly depends on the CPU, the speed of your system bus (or FSB, Front-Side Bus) is also important, since image data must be copied from the main memory to the video memory every frame.
make sure you Disable V-Sync
also keep the settings at default, rather than be tempted to change them ;)
get it here
AMD AM2 X2 4600 2.4Ghz
36.32fps
would be nice for screenys but i know your all lazy lol :cool:
harris1986 said:
i shall give it a blast on my conroe later today at 3.2 ghz try and raise the standard up a bit :D (jokz please don't hurt me)
lucky for you im setting of for a week abroad in oh.....10 minutes. so i couldnt care less :D
my cpu is at 3.62 and I got 27 lol..soon to get conroe ;)
I'm sorry but tbh I don't know how to do the screenie and show it some 1 might enlighten me pls.... :confused:
there's a print screen button on your keyboard....usually marked "Prt Scr" or something similar.
Just hit that and then open up mspaint and paste it in there. Then use imageshack.us or something to upload the file...then post the image code in here.
Many thanks will try it now lol..
Please don't laugh , but where does it store the image lol I did a print screen and now can't find it sorry... :(
lol print screen saves it memory (like when you copy and paste)
so its saved in memory now, open up microsoft paint and edit / paste it in there
host it with http://www.imageshack.us/
Ok I'll post mine up so everyone can feel better. Its an A64.
Thing is, it says I only just beat an 1700+xp, I have run that chip and others and at stock this machine is definetly faster.
Ram/FSB is 225
Animation appeared relatively smooth especially after the 1st test and it reminded me of a trippy old amiga demo :D
This machine handles dvd encoding, etc in reasonable times btw
The conroe rig above is probably hampered by poor drivers for that OS, the figure given by the program for conroe is 80fps.
Does GPU speed affect this ?
Ram/FSB is 225
Well his score is relative to mine clock for clock so I reckon someone is telling porkies ragrding the conroe = 80fps thing :confused:
