w3bbo said:<snip>
Xez said:Yours seems VERY low... Im clocked a lot slower than you are but get quite a bit more![]()
Soulja said:How do you disable vsync?![]()
Soulja said:i have a x1900xt, does my gfx not use it?![]()
MSPenguin said:I just ran this on my work machine which is a Dell Precision 490 - 2 processor dual-core XEON (8 threads) @3.2ghz and I get a horrendous figure of around 30FPS !![]()
Would this be the RAM slowing it down (2 x 2GB DIMMS running at 533mhz) ??![]()
silversurfer said:blah
MSPenguin said:Just checked CPU utilisation via Task Manager when running this and all 8 cores are pretty much maxed out. Only using 2 cores or turning off multithread etc. doesn't make any difference.
I'm beginning to wonder if it is something to do with the RAM. They are 2GB DDR2 ECC modules running at 533mhz. I might try taking the 2nd one out and see if it speeds things up.
Shame it's a Dell though, so I can't really do any overclocking or tweaking![]()
