Freesat help
I'll need a multibox then if I want sky and freesat in another room then.
Could anyone suggest one for me please?
Depends on how many feeds you will require?
Triax multiswitches - http://www.triax.co.uk/
I'll have a look at which one I got.
You can also feed your aerial (Freeview) into the same cable as Freesat/Sky but you need Diplex/Triplex wall plates to separte the combined feeds.
So this
and a quad lnb and I'm good to go?
And finally, what are the main differences between a quad and quattro lnb?
You need a Quattro LNB for use with a multiswitch. A Quattro LNB and multswitch is only needed if you require more than 8 feeds/outputs.
A Quad LNB allows for 4 independent outputs
A Octo LNB allows for 8 independant outputs
A Quattro LNB has 4 fixed outputs to conect to a multswitch
Read this http://www.satcure.co.uk/tech/lnb.htm#quattro
