Freezer trick - SUCCESS!
28 May 2007
Hi all,
Story to follow:
My father was using an older HP desktop to record his vinyl records. A casual "Have you made a backup?" from me got a "yeah I'll sort that out soon" reply.
..so the next week Windows blue screens on boot. Restarting, and the drive isn't detected by the BIOS, but there's the click of death now coming from it.
Considering the potential for a data recovery company to charge £400+ for a recovery, my father opted to merely start again with the recordings. But, since there was no real worry about trashing the drive, I figured I'd give a try to the freezer trick.
My logic being that the way things stood the drive couldn't finish its spin up routine without clicking, it wasn't being detected by the BIOS on any machine I tried it in, the data could all be recovered without the need for that drive.. so if I bricked it even further, we would be in exactly the same state.
I wrapped the drive first in paper towels (debatable move there.. aim was to keep the drive condensation free when it was removed from the freezer & became the coldest item in the room), and then placed the mummified drive in an anti static bag... With hindsight as I type this, that sounds like the most useless move in the world actually. *Facepalms*
Either way, it was left in the freezer for 24 hours. When I removed it, I connected it to the IDE header on my IP-35 board. It (with a couple of kur-clicks) managed to be recognised by the controller. Windows could see the partition table, but couldn't identify the main partition as NTFS, and instead insisted I needed to format it. Think not.
So, I rebooted into Ubuntu, and first tried to mount it:
# mount -t ntfs-3g /dev/sdc1 /media/blah
... no dice, NTFS-3G winced at the corruption and refused to budge.
Back in the freezer went the drive, while I searched for my next move. In searching, I found testdisk (http://www.cgsecurity.org/wiki/TestDisk). A sudo apt-get install testdisk later, I pointed Testdisk at my ailing drive and.. with a little delay (and a few clicks / crunches from the drive) it gave me a directory listing.
I headed to the folder containing the recordings and instructed testdisk to dump the data to another disk in my machine.
It only went and did it! It's recovered about 60% of the data (30gb total recovered) which is quite an impressive amount considering the number of errors that drive was throwing out (Not to mention its crunching and clicking). I didn't take any steps to keep the drive cool; after the 4-5 hour recovery period it was up to about 40c.
Either way, for me in this circumstance, the freezer trick helped my drive to complete its spin up routine, and testdisk managed to get the data back.
...and I'm sat here amazed and bemused! Hope this helps someone else, or if nothing else makes you all run your backups ;)
Yep worked for me as well. No need to leave it on there 24 hours though, a couple of hours should be fine. I attached mine with a USB adapter to a netbook and left it running whilst in the freezer still :D
Ah see I had intended to leave it for only a couple of hours, however I forgot it was there!
I might try the same trick; see if I can get a USB enclosure to work from within the freezer, and see if I can recover any further information from it.
I've done this before too. I put it in several bags and left it overnight. It was a bit wet etc in the morning, but it was enough to get my stuff back.
Nice to hear it works.
But its not nice to give me the slight paranoia that my hard drive is going to fail on me.
Nightmares for me tonight.
Guess i should backup again soon :P
LOL i thought i was the only one!. I froze it for about 5hrs then kept it in a mini 12v fridge to keep temps down. Got all relevant data back from the clients hdd! about 240gb worth :eek:
I have a hard drive here with some really important stuff on that i dropped. It no longer shows in windows etc and hadn't heard of this method before, but may as well try it now.
Can you post here or send us an email explaining what you did mate as i dont have a clue when it comes to this type of thing.
What did it hit? Also thats over 1/2 a metre! Hdds are extremely delicate, if it hit something hard at that distance theres a good chance of the internals being buggered.
Sometimes you have to put the effort in :D
you can also buy an identical drive and swap the PCB, if its the PCB that was faulty it will fix the problem, if its a motor / head issue obviously it will not help
Well it hit wooden floor but it was inside an maxtor enclosure (external)
Well i was told by someone i know that it could have knocked the 'head' out of place and unless i worked at a data recovery place then its not recommended to take it apart and look if it could be moved back into place.
Guys could i buy something like this...http://www.overclockers.co.uk/showproduct.php?prodid=HD-078-FC&groupid=701&catid=14&subcat=59 ?
Then send it there?
How would i know if its the pcb?
Even this is a iffy proposition. PCB has to be literally same batch, same firmware to have even a chance. Even then, since the SMART allocation and data is from another drive, it might not work.
Ive tried the freezer trick few times but its always failed... still had the click maybe didnt give it more testing however 2 weeks ago a customers old aging ide hdd died with a click and then came the dreaded sorry all your family photos are gone along with the ones of your recently passed father.... da usual story !
Anyhow I told her we use ibas and they charge £699.99 for recovery but id try something since she said not a chance to that, anyhow I took the drive smashed it flat on the floor put it back in and it got detected in bios and started to spin and detect fine !
Quickly transfered the files to a dvd since photos was only 2gig....
Gave the customer good news and told her shes lucky I just saved her £699.99, and she left without even giving me a tip.....
