In the bios, you will need to go to Audio Configuration & enable HD Audio controller page 3- 16 of the manual.
You also need to install Realtek HD Audio drivers. section A2 to A6 of the manual tells you what to install & how to set it up.
When you install the drivers you do need to restart pc afterwards.
Not to worry stulid, thanks for all your help and everybody elses. Turns out it was a lose connection that I had done on the motherboard. Very tight fitting connector, used some long nosed pliers (which I do not recommend) and forced it in.
