Full system specifically for Battle for Azeroth
1 May 2013
Hi all,
I am looking for a pre built gaming system that will run WoW BFA at ultra settings easily in all environments, I know WoW is more processor reliant rather than being GPU reliant so I have a budget of around £1100. I also need to have Windows as I am still running Windows 7 and don't have an upgrade. I don't really mind how the PC looks (lights, bells whistles etc) I just want it to do the job really.
I have seen a PC on Amazon:
Brand name ADMI
Processor Brand Intel
Processor Type Core i7
Processor Speed 4.70 GHz
Processor Count 6
RAM Size 16 GB
Memory Technology DDR4 SDRAM
Computer Memory Type DIMM
Hard Drive Size 1 TB
Hard Drive Interface Serial ATA
Graphics Card Description NVIDIA GeForce GTX 1060 6GB GDDR5 VR Ready Graphics Card
Graphics RAM Type SGRAM
Graphics Card Ram Size 6.00
Optical Drive Type None
Hardware Platform PC
Operating System Windows
https://www.amazon.co.uk/ADMI-GTX-1...e-bin:11416345031,p_72:419153031,p_36:-120000
This is £1,189.95
I am wondering if this would be okay for WoW or would I need something else?
I have been checking the OC forums and also seen this that someone recommended:
Case
Phanteks Enthoo Pro M Midi Tower Case with Window - Black
Memory
Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD416G24
Graphics Card
Asus GeForce GTX 1060 Turbo 6144MB GDDR5 PCI-Express Graphics Card
Solid State Drive (Primary)
Team Group TeamGroup 120GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
Solid State Drive (Secondary)
Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
Lighting
You can optionally select an item
WIFI
Operating System
Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
https://www.overclockers.co.uk/ocuk...e-i5-8600k-4.8ghz-fs-1bv-og.html#t=a6b1d,g9j4
I am just not sure if this would be good or would I better looking at AMD processors cause people have said they are better for WoW cause of cores? I am just a little lost looking through all this. Can anyone help or show me a system that would do the trick at all?
Many thanks.
CPU CoolerCooler Master Hyper 212X CPU Cooler
Optical Drive **Please Check Chassis Support**Not selected
Case LightingNot selected
Operating SystemMicrosoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
Processor Intel Core i7-7700K 4.2GHz (Kaby Lake) Socket LGA1151 Processor - Retail
MotherboardGigabyte GA-Z270-Gaming K3 Intel Z270 (Socket 1151) DDR4 ATX Motherboard
MemoryTeam Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD416G24
SpeakersNot selected
MonitorNot selected
Gaming ChairNot selected
SoundcardNot selected
Network AdapterNot selected
Power SupplyKolink KL-500 500W '80 Plus Bronze' Power Supply
Security SoftwareNot selected
CaseBitfenix Nova Midi Tower Case - Black
WD Black 256GB M.2 2280 PCIe NVMe Solid State Drive (S256G1X0C)
Solid State Drive 2Not selected
Mechanical Hard Drive 1Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
Mechanical Hard Drive 2Not selected
HeadsetNot selected
KeyboardNot selected
MouseNot selected
Graphics 2 Gigabyte GeForce GTX 1060 WindForce OC 6144MB GDDR5 PCI-Express Graphics Card
Total price £1140.90, anyone know if this would be okay? or any recommendations to it?
My basket at Overclockers UK:
  • 1 x OcUK Gaming Vision VR Gaming PC - Intel 8th Generation 3.6GHz Quad Core = £1,209.04
    • Processor:Intel Core i7-8700 3.2GHz (Coffee Lake) Socket LGA1151 Processor - Retail
    • Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD416G24
    • Graphics Card:palit GeForce GTX 1070 Dual 8192MB GDDR5 PCI-Express Graphics Card
    • Solid State Drive:TeamGroup 240GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • CPU Cooler:Alpenfohn Brocken ECO CPU Cooler - 120 mm
    • Case:phanteks Eclipse P400S Glass Midi Tower Case - Noise Dampened Black
    • WIFI:Unwanted
    • Security Software:Bullguard Anti-Virus 2017 - 1 PC 1 Year **Offer Price**
Total: £1,223.14 (includes shipping: £14.10)
This satisfies the BFA requirements for 70GB SSD space and greatly exceeds the CPU, GPU and RAM requirements.
WoW is usually a very single-core orientated game - where max core speed is key - but BFA is introducing DX12 support, which may mean better multi-core usage (and less reliance on single-core speed).
You could also just save yourself a lot of money and get this:
  • 1 x OcUK Kinetic H1M - Micro ATX Intel H310 Configurable Coffee Lake Gaming PC = £893.93
    • CPU:Intel Core i5-8500 3.0GHz (Coffee Lake) Socket LGA1151 Processor - Retail
    • Graphics Card:Asus GeForce GTX 1060 Dual 6144MB GDDR5 PCI-Express Graphics Card
    • Primary Storage Drive:TeamGroup 240GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • Secondary Storage Drive:Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
    • Optical Drive:Unwanted
    • WIFI:Unwanted
    • Lighting:Unwanted
    • Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
    • Security Software:Unwanted
    • Case:CoolerMaster MasterBox Q300L Micro-ATX Case - Black Window
Total: £908.03 (includes shipping: £14.10)
Again, this PC exceeds the min specs in all areas, but the CPU and GPU is slower than the above build. You may need to turn some ultra settings down slightly as the GPU is weaker..
But without proper BFA benchmarks, and requirements not being finalized, it's hard to pick the exact spec that can run BFA ultra 60fps+ everywhere.
Thanks for the reply, I am looking to spend a bit more to future proof the computer too, so the top one is looking great. Is there much difference between the i5 and i7 as well as the GTX 1060 and GTX 1070?
https://eu.battle.net/support/en/article/137431
@southernorth pre-build are above recommended , which has changed a lot since the expansion was announced - lot more coding has taken place and DX12 along with DX9 being dropped from their product range- wont be long before WOW ditches it.
big difference between the 1060 and 1070 specially if you want to run higher res and max framerates. I7 should hold more of a higher average frame rate when taking part in massive raids - specially on 1080p screen.
ryzen option with a much more powerful GPU- prob run 4k if you wish
  • 1 x OcUK Gaming Gigawattz - Limited Edition Ryzen 5 2600 Gaming PC = £1,169.99
    • Graphics:Gigabyte GeForce GTX 1070Ti Gaming 8192MB GDDR5 PCI-Express Graphics Card
    • SSD Option:Unwanted
    • Storage:Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
    • Case:phanteks Eclipse P300 Glass Midi Tower Case - Black
Total: £1,184.09 (includes shipping: £14.10)
system has a few tweaks that need to be done - changing of ram from 2400hz to 3000hz+
Ryzen 2600 will auto overclock for you as well and board will be able to handle ryzen 3*** and 4*** CPUs in the future .​
Ryzen is indeed a great option, but I'd just be concerned about the low RAM speed in that pre-built and the lack of an SSD.
I've seen a few YouTube videos testing DX12 mode in the beta, and multi-core usage doesn't seem much improved. We shall see when the game is more finished I guess.
always a kicker that, I hate why OCUK do that - they arent a dodgy cheap vendor selling on ebay so might as well list 3000hz + and up the price a little
ryzen - intel is best for gaming and ryzen not to far behind but slightly better value for money and nice to support the underdogs :D
It really seems like it. I done a custom build and could fit a GTX 1080 and a Ryzen 7 2700x into the one machine for less than £1300. Where the same build with the i7 was close to £1600. Just really strange the huge price difference for not a huge increase. I have read that RAM can be an issue with the Ryzen, is the 2400mhz speed okay or should I try and push that to the 3000mhz?
Case
Raijintek Arcadia Mid Tower USB 3.0 Case - White
Motherboard
Gigabyte Aorus GA-AX370-Gaming 5 AMD X370 (Socket AM4) DDR4 ATX Motherboard
Processor
AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail
Memory
Team Group *Build Stock* Vulcan T-Force 16GB (1x16GB) DDR4 PC4-24000C16 3000MHz - Grey
Graphics
Palit GeForce GTX 1080 Dual 8192MB GDDR5X PCI-Express Graphics Card
CPU Cooler
Raijintek Aidos Red CPU Cooler for Ryzen
Solid State Drive 1
Kingston A400 120GB SATA 6Gb/s 2.5" Solid State Hard Drive - (SA400S37/120G)
Power Supply
Operating System
Build Time
OcUK Professional Standard Build Systems - Dispatched within 7 working days
Came up with that on: https://www.overclockers.co.uk/ocuk...idi2$_2bidj2$_!bjoE2_Y)bjoF2_Y(bjoG2_Y'bnfS2w:)
Total price is £1,279.80, I think that would future proof the machine quite a bit, only thing I don't know about is the RAM since it's just 1 stick, you think that would be okay or should I look at different RAM?
Or can change the above build motherboard for: MSI B350 Gaming Plus AMD B350 (Socket AM4) DDR4 ATX Motherboard and the RAM to: Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black (CMK16GX4M2B30)
Results in about £10 more but I am willing to spend that to make sure the machine is good. Which build do you think would be better?
X370 is the better board .
Grab 16gb via 2x8gb sticks
I listed 1060 as thought you'd be gaming at 1080p . If screen res is higher 1440p then gtx 1070/70ti to save cash over 1080.
Also spec'd far superior PSU and larger SSD which would store WOW .
I am at 1080p, would the GTX 1080 be a waste?
If you haven't got a 144hz+ 1080p then yeah. It would last a lot longer playing games mind , that would be used as another though, most people that buy high end cards like that tend to keep for 2gens of GPU, though this time around currently Pascal 1*** series is getting old and older still ! Haha .
Gtx 1070ti is more appealing as it's cheaper and offers close to the raw horse power of the gtx 1080 - this you don't feel as bad and can justify it to your brain hah
I did a bit of tweaking to the build: https://www.overclockers.co.uk/ocuk...idi2$_2bidj2$_!bjoE2_Y)bjoF2_Y(bjoG2_Y'bnfS2w:,
Processor
Motherboard
CPU Cooler
Operating System
Build Time Standard Build Systems - Dispatched within 7 working days
Memory
Case Raijintek Arcadia Mid Tower USB 3.0 Case - White
Power Supply
Kolink KL-600 600W '80 Plus Bronze' Power Supply
Solid State Drive 1 TeamGroup 240GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND
Mechanical Hard Drive 1 Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
Graphics
MSI GeForce GTX 1070Ti Armor 8192MB GDDR5 PCI-Express Graphics Card
Price total is £1,329.95 - more than I want to spend but don't think I can squeeze anything more out of that. You think that build is solid enough and future proof?
  • 1 x OcUK Tech Labs AMD Ryzen Midi Tower Gaming PC Configurator = £1,232.82
    • Processor:AMD Ryzen 5 Six Core 2600 3.90GHz (Socket AM4) Processor - Retail
    • Motherboard:Gigabyte Aorus GA-AX370-Gaming 5 AMD X370 (Socket AM4) DDR4 ATX Motherboard
    • CPU Cooler:Alpenfohn Ben Nevis CPU Cooler - 120mm
    • Optical Drive **Please Check Chassis Support**:Unwanted
    • Case Lighting:Unwanted
    • Build Time:Standard Build Systems - Dispatched within 7 working days
    • Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
    • Case:Cougar Panzer Midi-Tower Gaming Case - Black Window
    • Power Supply:Super Flower Platinum King 550W 80 Plus Platinum Power Supply - Black
    • Speakers:Unwanted
    • Monitor:Unwanted
    • Gaming Chair:Unwanted
    • Soundcard:Unwanted
    • Network Adapter:Unwanted
    • M.2 Solid State Drive **For Operating System If Selected**:Unwanted
    • Solid State Drive 1:TeamGroup 240GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • Solid State Drive 2:Unwanted
    • Mechanical Hard Drive 1:Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
    • Mechanical Hard Drive 2:Unwanted
    • Headset:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Graphics:Zotac GeForce GTX 1070 Mini 8192MB GDDR5 PCI-Express Graphics Card (ZT-P10700G-10M)
Total: £1,246.92 (includes shipping: £14.10)
Unless your streaming, then 6 core 12 thread ryzen will be fine . Plus once Zen2+ rolls out in 2019/20 most could upgrade their chip to be fair - why x370 board is selected
Nothing is future proof, next Nvidia card will have edge over current has its v-ray support is via hardware etc etc
Intel build that would offer better gaming performance
  • 1 x OcUK Gaming Vision VR Gaming PC - Intel 8th Generation 3.6GHz Quad Core = £1,169.00
    • Processor:Intel Core i5-8400 2.8GHz (Coffee Lake) Socket LGA1151 Processor - Retail
    • Graphics Card:*Build Stock* Gigabyte GeForce GTX 1070Ti Gaming 8192MB GDDR5 Graphics Card
    • Solid State Drive:TeamGroup 480GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • CPU Cooler:Unwanted
    • Case:Phanteks Eclipse P400 Midi Tower Case - Black Window
    • WIFI:Unwanted
Total: £1,183.10 (includes shipping: £14.10)​
