For all you people out there considering a nice big SSD array for your virtualisation needs...
http://www.guru3d.com/article/memory/506/
Had to laugh...
I agree, just a shame it works on a IDE port and not a laptop port, We have an old laptop at home with a small harddrive and it would be ideal to have a 16GB cheap SSD for that.Interesting article tbh![]()
Does anyone know why the adapeters are only compatible with CF I/II and not the newer III and IV cards? Can't see the problem given that the pin layout on the CF cards is the same as that of the IDE interface?
Depends if the adapter card you have supports DMA mode. I have got 2 from the same place one does and one did not.. There is a site that shows you how to convert the card to a DMA version but I don't know the address. I would not bother on the bay and look at my post above to find the other site with them on.
The Type of the adapter is the size it accepts EG type 1 or 2 There are only 2 Versions.
The Type of the card is its speed rating normally sandisks version. Eg ultra ii / ultra iii / iv etc.. the speed of the card is normally shown as well as x44 speed you can work the speed out by 150Kb x 44 = 6600Kb or 6.6Mb a sec.
again wiki
There are four main speeds of cards including the original CF, CF High Speed (using CF+/CF2.0), a faster CF 3.0 standard and a yet faster CF 4.0 standard that is being adopted as of 2007
Rob.
The newer CF cards offer up to 133MB/s - fast enough?
