** G.SKILL RETURNS TO OcUK WITH THEIR MIGHTY TRIDENT X!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK is once again stocking G.Skill with their flagship Trident X range. Our prices are also very good as we purchased prior to all the memory price increase in the last week:-
G.Skill TridentX 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (F3-2400C10D-8GTX) @ £79.99 inc VAT
Working closely with its motherboard partners, G.SKILL has completed the compatibility validation tests between the current DDR3 memory kits and the latest Intel 7 series chipset-based systems. G.Skill guarantees all of its performance DDR3 memory kits are able to deliver the best performance and reliability with most popular Z77 motherboards in the market
In addition, all G.SKILL high speed DDR3 memory kits (including and above 1866MHz) have included the latest Intel XMP 1.3 profile support to Z77 motherboards. It allows PC enthusiasts to easily enjoy the high memory speed on the latest Z77 platform without setting the BIOS manually .
All G.Skill memory products come with a lifetime warranty and the G.Skill technical team is always ready to provide consumers with complete technical support via online forums, telephone and email.
Features:-
- Model Number: F3-2400C10D-8GTX
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Capacity: 8GB (4GBx2)
- Multi-Channel Kit: Dual Channel kit
- Tested Speed: DDR3-2400 MHz (PC3-19200)
- Tested Latency: 10-12-12-31 2N
- Tested Voltage: 1.65V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM
- Height: 54 mm / 2.13 inch
- Warranty: Lifetime
- Fan lncluded: No
- Features: Intel XMP (Extreme Memory Profile) Ready & Removable Top Fin
Only £79.99 inc VAT.
ORDER NOW
G.Skill TridentX 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (F3-2400C10D-16GTX) @ £149.99 inc VAT
Features:-
- Model Number: F3-2400C10D-16GTX
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Capacity: 16GB (8GBx2)
- Fan lncluded: No
Only £149.99 inc VAT.
ORDER NOW
G.Skill TridentX Fan 8GB (2x4GB) DDR3 PC3-19200C9 2400MHz Dual Channel Kit (F3-2400C9D-8GTXD) @ £89.99 inc VAT
Working closely with its motherboard partners, G.SKILL has completed the compatibility validation tests between the current DDR3 memory kits and the latest Intel chipset-based systems. G.Skill guarantees all of its performance DDR3 memory kits are able to deliver the best performance and reliability with most popular Z77/Z87/Z97 motherboards in the market
In addition, all G.SKILL high speed DDR3 memory kits (including and above 1866MHz) have included the latest Intel XMP 1.3 profile support to Z77/Z87/Z97 motherboards. It allows PC enthusiasts to easily enjoy the high memory speed on the latest Z77 platform without setting the BIOS manually .
Features:-
- Series: TridentX with Fan
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Tested Latency: 9-11-11-31 2N
- Fan lncluded: Yes
Only £89.99 inc VAT.
ORDER NOW
G.Skill TridentX Fan 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (F3-2666C11D-8GTXD) @ £99.95 inc VAT
Features:-
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Tested Speed: DDR3-2666 MHz (PC3-21300)
- Tested Latency: 11-13-13-35 2N
- Fan lncluded: Yes
Only £99.95 inc VAT.
ORDER NOW
G.Skill TridentX Fan 16GB (2x8GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (F3-2666C11D-16GTXD) @ £169.99 inc VAT
Features:-
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Fan lncluded: Yes
Only £169.99 inc VAT.
ORDER NOW
G.Skill TridentX Fan 8GB (2x4GB) DDR3 PC3-22400C12 2800MHz Dual Channel Kit (F3-2800C12D-8GTXDG) @ £161.99 inc VAT
Features:-
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Tested Speed: DDR3-2800 MHz (PC3-22400)
- Tested Latency: 12-14-14-35 2N
- Fan lncluded: Yes
Only £161.99 inc VAT.
ORDER NOW
G.Skill TridentX Fan 8GB (2x4GB) DDR3 PC3-23400C12 2933MHz Dual Channel Kit (F3-2933C12D-8GTXDG) @ £249.95 inc VAT
Features:-
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Tested Speed: DDR3-2933 MHz (PC3-23400)
- Fan lncluded: Yes
Only £249.95 inc VAT.
ORDER NOW
G.Skill TridentX Fan 8GB (2x4GB) DDR3 PC3-24000C12 3000MHz Dual Channel Kit (F3-3000C12D-8GTXDG) @ £329.99 inc VAT
Features:-
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Tested Speed: DDR3-3000 MHz (PC3-24000)
- Fan lncluded: Yes
Only £329.99 inc VAT.
ORDER NOW
This memory is for those who want extreme performance and great overclocking ability. If your looking for something more general but good quality then check out our Avexir, Kingston and TeamGroup range. :)
You want the best Xtreme Overclocking RAM for benching or extreme gaming.
G.SKILL is the top dog!!!
Great to see it back Gibbo!!
@8 Pack
I was origionally considering the Avexir Blitx 2x8gb 2400mhz .
Now seeing these would u reccommend the
2x8gb 2400mhz
or
2x8gb 266mhz
its for a new devils canyon build
Only if they made blue and orange ram :(
G.Skill is about max performance and overclocking, not aesthetics.
If you want Aesthetics then check Team and Kingston, they do the colours you want and offers speeds in the 1600-2400MHz region. :)
@ Gibbo
Possible wrong Information. In the product descriptions. Lots of reference to Z77
"In addition, all G.SKILL high speed DDR3 memory kits (including and above 1866MHz) have included the latest Intel XMP 1.3 profile support to Z77 motherboards. It allows PC enthusiasts to easily enjoy the high memory speed on the latest Z77 platform without setting the BIOS manually ."
Ill assume probably should be Z97
Cheers, ram performance doesn't bother me one bit as it is mostly just about bragging rights.
I'm looking at doing a orange and blue build so I need2x4gb blue sticks and 2x4gb orange sticks preferably from the same brand at the same speed and timings to avoid compatibility issues. Any suggestions gibbo?
Thanks but those are LEDs mate I was thinking of the actual paint on the heat sinks of the ram
i am personally not aware of a manufacture that produces both blue/orange pained memory. And a quick check of OCUK means possibly having to look else where.
Checking with Sales support. Some manufactures allow removal of heatsinks for Watercooloing.
So just go with brand that allows this and Paint them. if any issues send away without heatsinks and say they were watercooled
Which brands support the removal if you don't mind me asking?
If you can do a £100 today's only deal for the G.Skill TridentX 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (F3-2400C10D-16GTX) I'll buy another pair. :D
