Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Competitor rules
It's on, and working. Had to re-install the drivers and i though't i'd install the MSI stuff as well. So just doing that now and then will see where i'm at!
Nice! Rember to keep an eye on your temps and everything as usual and you will be golden. If your looking for any info look in that thread i linkedm theres loads of people scores and how much voltage etc.
You should be able to add up to +200mv via AB iirc, whack the fan to max rpm and start increasing core/voltage and leave the vram on stock, once you hit the limit, drop it down a touch for stability.
Then do the vram clocking with core on stock, you'll know when it's at it's limit as it'll either corrupt/lock up PC/black screen, then back off.
Then set both clocks and run some BM's.
Make sure you don't have 'apply oc at start up' on AB selected as worse case scenario-it can cause blue screens at start up resulting in having to uninstal AB in safe mode.
PS, if it was mine, and if that cooler does what I've read it can-the LTG's were built for pain=tames 290X temps, I'd add +300mv(via AB switch) from the off and ramp it straight to 1200MHz.
I would prob go for up to +400mv and have a play if the cooler is as good as they say it is.
Just seen your best was 1160 on the stock bios! With 100 volts to play with this gunna be fun That ln2 mode and extra power cable showing its worth alright
