Caporegime
- 11 Mar 2005
- Leafy Cheshire
Freefaller said:Good point - didn't think of that - though do they not get hot when you put the heater on full blast?
Not sure how other people have done it but i'm going to get some blanking disks and seal the vents off with just enough room for the gauge to be mounted in, i mean its such a small cabin no need for center vents and the extra air will just come out the side ones
I will post some pictures once i've done mine
It's getting better every day... and the centre console is getting retrimmed anyway, so it'll be pretty smart when it's all done. Will probably spray it black when it's smooth just to hide the filler until I can afford to get it retrimmed.
